Air Conditioner - HVAC - DIY Chatroom Home Improvement Forum
Old 09-14-2010, 07:27 PM   #1
Air Conditioner
Someone please help me. I have a totaline air conditioner the temp on the thermostat is set on 70 but thermostat is reading that is 93 degress in the house. How do I calibrate the thermostat to get it cool?
thank you
Last edited by batcgray; 09-14-2010 at 07:28 PM. Reason: to make sentence clearer.
batcgray is offline   Reply With Quote
Old 09-14-2010, 07:31 PM   #2
HVAC / Plumbing
is the a/c unit working ??? What makes you think it's the t.stat ??
kenmac is offline   Reply With Quote
Old 09-14-2010, 07:40 PM   #3
An old Tradesmen
Rewards Points: 7,370
The icicles on his nose.
Old 09-14-2010, 07:42 PM   #4
yes it works, but the fan is running but its not cooling off.
Old 09-14-2010, 07:44 PM   #5
An old Tradesmen
Then maybe your stat is reading the right temp. And its your A/C that has the problem. Is the small line warm, and the large line cool/cold at the outdoor unit.
Old 09-14-2010, 07:50 PM   #6
I think it needs to be reset, but I don't know how to reset the thermostat. This unit is set automatically set the thermostat to heat when the weather starts to cool off and automatically set when the weather starts to heat up, but the only problem is that's still out outside and I cant reset the thermostat. does that make any sense?
Old 09-14-2010, 07:54 PM   #7
An old Tradesmen
Not 100%.
Look at your thermostat, for a system switch, or mode button.
Old 09-14-2010, 08:03 PM   #8
I have a mode button.
Old 09-14-2010, 08:04 PM   #9
An old Tradesmen
Push it, until the screen says cool.
Old 09-14-2010, 08:10 PM   #10
I've tried that already. It will display cool but the unit is not kicking in to make it cooler.
Old 09-14-2010, 08:23 PM   #11
HVAC / Plumbing
do you have a split system ?? Is the blower blowing air out the vents... Check outside unit & see if it's running
Old 09-14-2010, 08:30 PM   #12
An old Tradesmen
There very well may be a problem with your unit, and not your thermostat.
Old 09-14-2010, 08:32 PM   #13
I'm going outside to check the unit to make sure that it is running.
Old 09-14-2010, 08:39 PM   #14
the unit is on, but it is making a buzzing noise.
Old 09-14-2010, 08:42 PM   #15
HVAC / Plumbing
is the fan on top turning ?? Feel the large line (with insulation) on it is it cold / cool ?
Take care of him Been. I've got to go
New Air Conditioner trips breaker Cano Electrical 4 07-11-2010 10:29 AM
Air Conditioner Wiring Cano Electrical 3 06-28-2010 07:18 AM
Heat pump vs. Furnace and Air Conditioner heating&cooling HVAC 11 06-16-2010 06:07 PM
air conditioner tripping at current interrupter donny.frankrice HVAC 10 07-07-2009 02:08 PM
Air Conditioner HELP jray2855 HVAC 6 06-30-2006 08:41 AM
