-   -   Air Conditioner (http://www.diychatroom.com/f17/air-conditioner-81446/)
batcgray 09-14-2010 08:27 PM
Air Conditioner
Someone please help me. I have a totaline air conditioner the temp on the thermostat is set on 70 but thermostat is reading that is 93 degress in the house. How do I calibrate the thermostat to get it cool?
thank you
kenmac 09-14-2010 08:31 PM
is the a/c unit working ??? What makes you think it's the t.stat ??
beenthere 09-14-2010 08:40 PM
The icicles on his nose. :laughing:
batcgray 09-14-2010 08:42 PM
yes it works, but the fan is running but its not cooling off.
beenthere 09-14-2010 08:44 PM
Then maybe your stat is reading the right temp. And its your A/C that has the problem. Is the small line warm, and the large line cool/cold at the outdoor unit.
batcgray 09-14-2010 08:50 PM
I think it needs to be reset, but I don't know how to reset the thermostat. This unit is set automatically set the thermostat to heat when the weather starts to cool off and automatically set when the weather starts to heat up, but the only problem is that's still out outside and I cant reset the thermostat. does that make any sense?
beenthere 09-14-2010 08:54 PM
Not 100%.
Look at your thermostat, for a system switch, or mode button.
batcgray 09-14-2010 09:03 PM
I have a mode button.
beenthere 09-14-2010 09:04 PM
Push it, until the screen says cool.
batcgray 09-14-2010 09:10 PM
I've tried that already. It will display cool but the unit is not kicking in to make it cooler.
kenmac 09-14-2010 09:23 PM
do you have a split system ?? Is the blower blowing air out the vents... Check outside unit & see if it's running
beenthere 09-14-2010 09:30 PM
There very well may be a problem with your unit, and not your thermostat.
batcgray 09-14-2010 09:32 PM
I'm going outside to check the unit to make sure that it is running.
batcgray 09-14-2010 09:39 PM
the unit is on, but it is making a buzzing noise.
kenmac 09-14-2010 09:42 PM
is the fan on top turning ?? Feel the large line (with insulation) on it is it cold / cool ?
Take care of him Been. I've got to go
