Air Conditioner - HVAC - DIY Chatroom Home Improvement Forum
Old 08-04-2011, 06:23 PM   #1
Air Conditioner
How far from the air handler can an air conditioner compresser unit be located? What are the extra costs, trade offs be for remote location?
Buddyo is offline   Reply With Quote
Old 08-04-2011, 06:30 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,276
50 feet is what the manufacturers recommend. After that you have to increase the size of the larger copper suction line and that gets REAL expensive. Can also develop problems with oil return to the compressor and shorten the life of it if the line is not installed PERFECTLY according to the manufacturers spec. We avoid going over 50 feet like the plague.
Read this post to see what can go wrong when the line is too long or not installed properly.
install line damage
Old 08-05-2011, 12:22 AM   #3
REP
With increased sizing and proper piping techniques I have seen with my own eyes lineset lengths of 100 feet.
Every manufacturer will have this info at the ready iuf needed.The units I seen were Trane but I would expect that otrher companies won't allow it.
I'm not even sure that with the new scroll compressors in Trane if its OK .You would need to find out as I beleve its not the normal and niot the same forb every unit.
REP is offline   Reply With Quote
Old 08-05-2011, 04:58 AM   #4
An old Tradesmen
Rewards Points: 7,372
Virtually all brands allow long line sets. Sometimes special piping considerations are done/accounted for. There are capacity derates for the longer line set run. Most install manuals don't contain all the info needed for a long line run. Sometimes its better not to increase the vapor line, due to oil return concerns.
I have line sets in excess of 180 foot. Still original compressors, after 15 years.
How I can repair My new air conditioner that drip water into my room? skolo HVAC 7 07-15-2011 11:12 AM
Air Conditioner Woes junoinga HVAC 2 03-19-2011 01:58 PM
New Air Conditioner trips breaker Cano Electrical 4 07-11-2010 10:29 AM
Heat pump vs. Furnace and Air Conditioner heating&cooling HVAC 11 06-16-2010 06:07 PM
Air Conditioner HELP jray2855 HVAC 6 06-30-2006 08:41 AM
