Air Condition Question On Fan - HVAC - DIY Chatroom Home Improvement Forum
Old 10-10-2011, 08:00 PM   #1
air condition question on fan
air handler motor that has went bad and have removed it from unit.
I can't get blower fan off motor shaft and unit is only three years old.
Ashleysailor is offline   Reply With Quote
Old 10-10-2011, 08:45 PM   #2
I spray wd40 on the shaft, use sand cloth on the shaft respray shaft and get crescent wrench and secure blower wheel while carefully turning shaft back and forth. It take patience but it has always worked for me. Whatever you do do not beat on the shaft.
thestig3 is offline   Reply With Quote
Old 10-10-2011, 09:07 PM   #3
JJboy's Avatar
You need a puller.
http://www.ebay.com/itm/3-JAW-SMALL-...item43a5137718
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
DRIcore question trailblazer1229 Flooring 0 02-24-2010 10:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 01:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 09:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 05:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
