Air Condensor Motor Help. - HVAC - DIY Chatroom Home Improvement Forum
Old 08-19-2009, 12:28 AM   #1
Air Condensor motor help.
I have an old Montgomery wards air conditioner. M/N SRM-51332A.
The motor died, it's part number is :K55HXMPZ-6560. It is an Emerson.
I got an Emerson 5462 to replace it.
http://www.emersonmotors.com/products/ecatalog.htm. I can't get a direct link to the page, so simple put 5462 in the part number search box(method 3) and it will pull it up.
The old motor has 4 wares coming off it, the new one has 5 wires, plus a green ground wire and a yellow and orange wires that I can use to change the motor direction.
How do I hook this up?
It looks like the Black and Red wires attach to the connector switch, and then brown and white connect to the capacitor. I don't know where to connect the remaining brown/white stripe wire. I did notice if it touched then chassis of the unit the motor will spin.
Natural the wires have a different color scheme on each motor.
Any help would be appreciated. I can send pictures of the wiring area in the condenser if needed.
Thanks.
Geekoid is offline   Reply With Quote
Old 08-19-2009, 11:42 AM   #2
Rewards Points: 1,596
Any wiring diagram in/on the box, on a paper, or the motor?
bob22 is online now   Reply With Quote
Old 08-19-2009, 12:57 PM   #3
Not for the old motor.
I do have the wiring Diagram for the new motor. I will post a link to it's image when I get home tonight.
Old 08-19-2009, 02:27 PM   #4
GC/Master Plumber/Mech
Rewards Points: 560
Thanks.
Black is high speed (A/C tap)
Orange is Med speed (Heat tap)
Red is Low speed
White is netural
Brown and Brown w/white strip is capacitor
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 08-19-2009, 03:07 PM   #5
Awesome, thanks.
I'll try it when I get home. I don't have an orange wire, but I assume the others are the same.
I have Red, White, Black, Brown Brown/White.
The precious motor was only one speed, 1075, so do I just disregard the low speed wire(red), or does it need to be connected with the high speed wire(black)?
Thanks again for your help, can't wait to get my AC going again.
Old 08-19-2009, 05:20 PM   #6
Rewards Points: 560
Red is Low speed (Heat tap)
White is netural
Is this in a Mobil or Modular home?
Old 08-19-2009, 05:42 PM   #7
It's a stand alone single family dwelling built in '79.
Neither mobile or modular.
Why?
Thansk again for your help.
Old 08-19-2009, 05:52 PM   #8
Rewards Points: 560
Old 08-19-2009, 06:00 PM   #9
Rewards Points: 560
OK I just googled the motor number and it is a condenser fan motor.
Forget the wiring I told you earlier and use this,
Black - contactor T1
Red - contactor T2
Brown and Brown w/ white stripe goes to capacitor
Fan blows air out the top.
Old 08-19-2009, 06:12 PM   #10
OK, cool.
Thanks.
Where does the white wire go?
Old 08-19-2009, 06:15 PM   #11
Rewards Points: 560
Switch the red and white. Put white to the contactor and tape off the red.
Old 08-19-2009, 06:17 PM   #12
will do.
Old 08-19-2009, 09:20 PM   #13
That set up didn't work.
How do I know if the previous motor was 3 line circuit or 4 line circuit?
The direction you gave(thanks again) seemed to be for the 4 line circuit.
How would it be set up for a 3 line. I found the wiring diagram, but frankly I don't understand it.It seem to say the brown wire goes to the cap, the white wire goes to the cap and to the 220 line, the brn/wht wire goes to the 220 line as well.
here is a link to the diagram:
http://www.flickr.com/photos/41636297@N07/?saved=1
oh, I don't know if it matters but the connector had a t1 and t3 label, no t2.
Old 08-19-2009, 10:43 PM   #14
OK, somehow I pop the 30A slow blow fuse. How I did it without knowing is beyond me.
The hook up you suggested works. Thank you very much.
Tags
5462 , emerson , wiring
