Air In Baseboard Heating Pipes - HVAC - DIY Chatroom Home Improvement Forum
Old 02-23-2008, 09:48 AM   #1
air in baseboard heating pipes
In just the last few weeks we've gotten air in our baseboard hot water heating pipes, there's gurgling noise in both circuits when it starts and then again when it stops circulating. We haven't had any work done in several years other than annual boiler cleanings (last one in the fall). The gauge says 18psi, which is what it's always been. Any idea why it would suddenly develop air after all these years? There's no sign of leakage. Could I have a problem with the expansion tank? We're in a splitlevel house.
dangerouswithtools is offline   Reply With Quote
Old 02-23-2008, 12:20 PM   #2
Have you bled th system?
redline is offline   Reply With Quote
Old 02-23-2008, 02:49 PM   #3
air in lines
there are many ways air can enter system small leaks bad seals like circulator flange gasket seals even the mechanical seals in the boiler sections them selves that join the multiple sections another way is make up water usually when you have an expansion tank problem like water logged your boiler pressure rises and u start leaking out the pressure relief also depends on expansion tank type
Boilerman20 is offline   Reply With Quote
Old 02-23-2008, 02:49 PM   #4
Air can collect in the system as it comes out of solution in the water. (When water is heated, gasses dissolved in that water have lower solubility in warm water than in cold water, so as the furnace heats the water, air can be created.) Just bleed the system, and you should be fine.
NateHanson is offline   Reply With Quote
Old 02-23-2008, 04:37 PM   #5
Thanks, now I know its not the expansion tank. I bled some air today out of both the upper and lower level circuits. The upper level doesn't have very much pressure, the water dribbles out, while on the lower level it's a projecting stream of water. Any idea what psi I should have in the system? I pulled on the lever that allows water into the system and I can hear some water moving in, but it doesn't sound like much and the pressure gauge isn't moving.
Old 02-24-2008, 02:03 PM   #6
You will have to bled it a few different times to get the air out.
Is the psi gauge working?
Is there an auto fill on this unit?
Old 02-24-2008, 02:19 PM   #7
I guess it's an autofill, it's right behind a backflow preventer on the water source line. It has a spring loaded lever that you lift and water enters the system. The psi gauge moved up a little bit when I opened this up for a minute or two. It has a threaded bolt with a flathead screw top that is secured at the bottom with a nut, I wonder if that controls the pressure.
Old 02-24-2008, 06:26 PM   #8
yes it is an autoflow usually boiler pressure is 12-15psi
Heating Pipes knocking kabuti HVAC 5 02-12-2008 08:00 PM
blockage in hot water heating pipes? gary in co HVAC 1 01-18-2008 03:36 PM
Baseboard heating overpressure puzzle palmpilot HVAC 9 12-26-2007 11:53 AM
Baseboard Heating Question RM2865E Plumbing 2 12-09-2007 08:01 PM
Baseboard heat not heating house.. Please help wadams HVAC 2 12-06-2007 08:12 AM
