Old 01-29-2009, 07:32 PM   #1
AH - Fan Speed - How to determine
Now that I have finished the upgrade of the main trunk lines in the basement, I am trying to figure out how to determine what the right fan speed would be for my AH.
It is a fixed speed unit, which means by moving the the wires I can change from slow/med/high.
It is a 5 ton comfortmaker AH matched with a 5 ton Heat Pump. What other info would one need to determine the optimum fan speed?
I have monitoring setup in that I can tell the suction line temp, the liquid line temp, the return (input) air temp and the supply air temp after going through the AH.
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 01-29-2009, 07:52 PM   #2
JohnH1's Avatar
Do you have the Mfg specs on the AH and HP. A basic 5 ton a/c will need 2000 cfm. If you have the blower curve info on the AH you can check the static pressure then look at what blower spped you are at and cross to the CFM. The best CFM is whatever the MFG says it should be for your condenser AH match up.
JohnH1 is offline   Reply With Quote
Old 01-29-2009, 07:53 PM   #3
JohnH1's Avatar
Only after proper CFM is set up can the A/C be properly charged.
Old 01-29-2009, 08:10 PM   #4
An old Tradesmen
Hmmmm.
Why was I thinking you had a Goodman.
Old 01-29-2009, 08:26 PM   #5
hvaclover's Avatar
Be nice to the DIYer Been.
Just slow, not stupid.
hvaclover is offline   Reply With Quote
Old 01-29-2009, 08:27 PM   #6
hvaclover's Avatar
Need to know the house sq ft first.
Old 01-29-2009, 08:30 PM   #7
An old Tradesmen
I could have sworn he said he had a Goodman in another thread.
Old 01-29-2009, 08:34 PM   #8
hvaclover's Avatar
He did and they were mismatched off the website he bought them from.
Old 01-29-2009, 08:39 PM   #9
Yes I have a Goodman. Fourth one in the family. (All working great.)
No I did not buy it online. I bought it from a local dealer.
The AH is a 5 ton 12 seer unit
The Goodman is a 5 ton seer unit.
Background info can be found in these posts.
HVAC - Airflow Issue
-Andrew
DIY hobbiest
Old 01-29-2009, 08:39 PM   #10
hvaclover's Avatar
http://www.metacafe.com/watch/115041..._conditioning/
Old 01-29-2009, 08:43 PM   #11
hvaclover's Avatar
My bad.Sorry.
Old 01-29-2009, 08:45 PM   #12
Originally Posted by hvaclover View Post
Sure I can whip up one of those for each room.
Sometimes you do what you have to do to get cool air....dumping some ice in that cooler would give a nice boost too.
-Andrew
DIY hobbiest
Old 01-29-2009, 08:46 PM   #13
That is where I was heading. From all the reading I have done, every HVAC guy I have had out has failed to do what I would think would be the proper way to measure the system.
So I am on a mission to figure it out myself so that it is done right.
-Andrew
DIY hobbiest
Old 01-29-2009, 09:01 PM   #14
hvaclover's Avatar
Your ok Andy.
Old 01-29-2009, 09:56 PM   #15
An old Tradesmen
You'll find Comfortmaker uses a different CFM on their heat pumps then what Goodman does.
So, you can't actually ever have proper air flow for it.
ou can download the specs for your Goodman outdoor unit you have, and see if you can match its rated performance.
Goodman includes the temp rise it shold have. But, that swith its rated matched coil.
how to build a single phase induction motor sashman Electrical 3 03-31-2011 08:18 AM
Chain saw Barry J Landscaping & Lawn Care 7 01-28-2009 02:11 AM
Trane XV80 - low speed fan not working oregondean HVAC 4 01-12-2009 01:46 PM
Two Speed Compressors rjordan392 HVAC 2 08-26-2007 02:32 AM
Slowing fan motor speed in air handler Manuel6 HVAC 7 04-17-2007 10:01 AM
