Old 03-21-2011, 09:11 PM   #1
After installing thermostat, heat/ac will not turn off
I just installed a Honeywell RTH2300 in my home to replace an old mercury unit. It appears to be somewhat working, but the AC/Heat will not shut off. For example, it is set at 75 and the ac keeps running down indefinitely. Also, when the thermostat is switched to the 'off' position, the heating/ac unit keeps running and stays on.
I have read the owners manual and installation guide cover to cover and nothing seems to jump out as something I did wrong. Any help would be appreciated!
mgreer65 is offline   Reply With Quote
Old 03-21-2011, 09:19 PM   #2
Professional
post picture. post wire colors and terminals connected to. ensure fan switch is in auto.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 03-21-2011, 09:26 PM   #3
Here is the picture. I tried to troubleshoot in both settings (on/auto).
-Michael
Old 03-21-2011, 09:32 PM   #4
Professional
cut the wire back. you have way too much copper exposed!
IT IS WHAT IT IS
The Following User Says Thank You to hvactech126 For This Useful Post:
mgreer65 (03-21-2011)
Old 03-21-2011, 09:34 PM   #5
Ok, can do. I was going to, but I wanted to ensure it worked properly first. I didn't want to cut it, later need it, and wish I had not have done so. Is this the problem?
Old 03-21-2011, 09:40 PM   #6
Professional
red and green look like they are touching which will bring on the fan 24/7
IT IS WHAT IT IS
Old 03-21-2011, 10:07 PM   #7
Alright, the red and green were not touching, but they were close, so I removed the excess copper, cleaned up in there a bit, and hooked everything back in. The unit appears to be functioning normally now. Thanks so much for your help!
After installing thermostat, heat/ac will not turn off-inside2.jpg
Old 03-21-2011, 10:11 PM   #8
Professional
no problem. they were probably touching when you attached the thermostat to the sub base.
IT IS WHAT IT IS
Where should I connect the thermostat ? DIY_user HVAC 2 01-11-2011 01:36 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
Carrier Edge Thermostat Installation Issue ptalar HVAC 1 07-13-2010 06:40 PM
Help Installing Honeywell Thermostat.... jobondur HVAC 14 03-30-2010 11:01 PM
Installing new thermostat Jarhad HVAC 1 02-28-2010 03:39 PM
