-   -   Advice on replacement system (http://www.diychatroom.com/f17/advice-replacement-system-41567/)
Wayne09 04-01-2009 10:33 AM
I would appreciate any comments or suggestions on the following bids: Work: Replace existing furnace in 10,000 sq. ft. single-story brick home. Bid #1: $4,995.00 Trane 80% efficiency gas furnace Trane XR13 2-ton 13 SEER heat pump. Bid #2: $5,995.00 Trane 80% efficiency gas furance Trane XL15i 2-ton 14 SEER heat pump. Bid #3: $4,850.00 Carrier 58 STA070-1-08 80% efficiency gas furnace Carrier 25HCB 330 A003 2.5 ton 13 SEER heat pump Carrier CNPVP3014ACA Coil. Thank you
kenmac 04-01-2009 12:13 PM
All prices are fairly close.. Must be about right for your area.. Are these R22 systems or R410 ? I would suggest a 90+ furnace instead of the 80 shouldn't be alot higher in price.. If you have to upgrade any venting with the 80 you may break even with a 90...
beenthere 04-01-2009 12:18 PM
Doesn't look like real bids.
sweaty 04-01-2009 01:11 PM
A 10,000 sq. ft. single story home? Is it a warehouse? Is that number accurate?
If so, it seems like a commercial system might be the right one. Get the highest efficiency system. And certainly, seal and insulate that warehouse.
jogr 04-01-2009 01:31 PM
From the equipment size I'm guessing he meant 1000 sq ft. The bids look typical. Why not go to 90%to 95% efficiency units? Gas isn't going to get cheaper.
yuri 04-01-2009 02:15 PM
Looks like they intend to use the heat pump for primary heat and the furnace for backup hence the 80% mid. A heat pump and high efficiency would be redundant. Where do you live Wayne?
kenmac 04-01-2009 03:40 PM
I would check the utility rates see which is cheaper in his area to operate. If gas would be cheaper I would just go all gas with atleast 90+
Wayne09 04-01-2009 05:28 PM
More Info
Hi All, I meant 1,000 Sq. Ft. The bids are real. I live in Richmond, VA. The heat pump would be the primary source; furnace for very cold periods. Thanks for everyone's help.
yuri 04-01-2009 06:06 PM
I would talk to your electric utility and see if they have a cost analysis for heat pumps and electric strips for supplemental heat vs heat pump and gas furnace vs 92% high efficiency furnace with standard A/C unit. Heat pumps lose efficiency at the lower temps and require more backup heat. A standard furnace and A/C in the long run may be a lot more reliable. Most heat pumps are used with coil blower/airhandler units with electric elements for supplemental heat. The heat from a heat pump is usually cooler and less comfortable. We cannot comment on pricing very well as it varies greatly from city to city, state to state. Personally I would buy a Lennox G71MPP or G61V furnace with high efficiency ECM motor and a XC15 SEER airconditioner. Incredibly smooth,quiet matched set and VERY efficient together. Will cost less to run those 2 than any heat pump combo.
http://www.lennox.com/
moondawg 04-03-2009 08:47 AM
How much yard to you have? Have you considered geothermal? Tax incentives make it competitively priced. And you'll use ALOT less energy to heat/cool your home!
