Old 11-23-2006, 12:36 PM   #1
Advice Needed re: Chimney Liner for Oil Furnace
Hi, Our home has an oil furnace and oil hot water heater. They both used to vent through the same 8" square masonry chimney, but the chimney cleaner found some large gaps between the flue tiles and recommended a chimney liner. We had the work done, but I'm worried that the liner they installed is too small. Both the furnace and the water heater had 6" round vent pipes. In order to connect them to the liner, they made a "Y" connection between the appliances into one 6" round pipe, then reduced that to 5" and connected it to the liner. So we've gone from two 6" stacks to one 5" stack. It seems to be drawing fine, but I'm worried about the possibility of backdrafts, carbon monoxide, etc. The heater is 120,000 BTU max but has a .85 gallon/hour nozzle, and the water heater is a 30 gallon unit with a smaller oil burner. (I don't know the BTUs for the water heater.) The chimney is approximately 30 feet high.
If anyone can advise us whether this is a safe installation, I'd appreciate it.
Thanks,
Mike
Mike_R is offline   Reply With Quote
Old 11-24-2006, 12:32 PM   #2
Thoroughbred Mopar Man
Hi Mike R
You need to have them come back and put in an 8" flue. You are never supposed to go smaller on the flue than the appliances they are connected to. The ratio we use for gas appliances is add 1" for the secondary appliance which is usually the water heater. But for oil or wood you add 2" for the secondary appliance. You didn't say what type of pipe they installed, but if it is exposed it has to be the high temp stainless. A standard type B pipe will melt under the heat. Hope this helps.
Good luck
Rusty
#CARRIERMAN is offline   Reply With Quote
Old 11-27-2006, 01:26 PM   #3
Hi Rusty,
Thanks for your helpful response. The chimney liner is never exposed, but runs up through the existing masonry chimney. Hopefully it is the high temperature steel, but I will definitely ask them to install a larger liner.
Thanks,
Mike
Old 11-27-2006, 04:04 PM   #4
Hi Mike R
I will be able to sleep better knowing you are adressing this. Just make sure they use the high temp stainless liner for wood, pellet, and oil. Outside of that you should be good to go for years.
Good luck
Rusty
More On This Topic
Ice fishing is a popular pastime in the northern states where the lakes and rivers freeze. The ice fishing houses range in sophistication from a little pup tent to a fully built, functioning home. There are several ways to heat the ice fishing house... Read More »
Hi! This is Jon on behalf of Expert Village. In this video clip I will be showing you how to check your furnace filter. The first thing you need to do is locate your furnace. Now in many houses, the furnace is located in the laundry room which is in the... Read More »
If you're living in a mobile home and facing your first winter, you may not be aware how difficult it can be to keep a mobile home warm. Taking the proper steps to winterize your mobile home cannot only help keep you warm, but keep your heating bills... Read More »
Hi! This is Jon on behalf of Expert Village. In this video clip, we will be checking our chimney. Now if you have a chimney that is brick or block, you are going to want to check the mortar to make sure that none is loose or deteriorated or any missing... Read More »
Hi, in this section we're going to talk to you about heating the shanty, very important. We run a propane tank on the outside, typically it's a twenty gallon propane tank with a 5 - 12 foot hose. It's very important to have the right parts for this, the... Read More »
Chimney Liner vs New Furnace jeff_connors HVAC 4 01-11-2007 01:41 PM
Chimney Liner for Water Heater mruggeri001 HVAC 6 01-10-2007 07:08 AM
Need New furnace advice. Unregistered HVAC 3 10-23-2006 10:13 PM
Stainless chimney liner relining systems Lisalovespainting HVAC 2 08-09-2006 06:48 AM
Chimney Liner johnsonteam1058 Building & Construction 1 10-01-2005 11:39 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
