Advice For Installing Duct Work For Finishing Basement - HVAC - DIY Chatroom Home Improvement Forum
Old 05-11-2011, 10:21 AM   #1
Advice for installing duct work for finishing basement
Hi,
I am looking for a little help with the duct work that I am adding as I am finishing my basement. I am adding vents to three rooms (bathroom, bedroom, and all purpose room). I am not going to add any new vents to my great room since I will have a fireplace that can heat the area. I am also adding probably two returns in the center of the basement. As I start this process, I am curious to know if there are any tricks that would make cutting out the holes for the vents easier. I am using a couple of takeoffs for two of the rooms. These are not round and they are in very tight spaces where I am having problems using tin snips. I will be using flexible duct for all the rooms. Any guidance would be greatly appreciated!
Thanks again.
JB
captainj98 is offline   Reply With Quote
Old 05-11-2011, 07:01 PM   #2
An old Tradesmen
Rewards Points: 7,328
For tight spaces, off set aviation snips work best.
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 05:18 PM
Whole house fan using old soffit duct work zacman General DIY Discussions 11 06-19-2010 11:57 AM
adding duct work and outlet jjrbus HVAC 17 05-30-2010 02:13 PM
Toughest duct work I can get? napper HVAC 7 07-30-2008 10:52 AM
Tiger Foam On Duct Work atw58 Building & Construction 1 04-25-2008 10:25 PM
