Advice On A Hummer - HVAC - DIY Chatroom Home Improvement Forum
Old 04-13-2009, 11:08 AM   #1
Home Air Direct's Avatar
Advice on a Hummer
Hey Pros, I need some advice.
I have been presented with the following situation and could use your expertise. Homeowner has a brand new Whirlpool 93% gas furnace (Armstrong in disguise). It was started and ran great for a few days. Very quite and went through the traces as usual. A couple days ago he noticed that when not operating, there was a pretty loud humming noise coming from inside. He removed the door and said that there was a loud humming coming from the control board. He went through the steps of touching all the components, blower, draft inducer, etc to see if it was resonating from elsewhere, but it appears to be from the board. He said that it was almost vibrating.
Any thoughts on what this could be? He did not say anything about the 24V transformer. That is my first thought. I am going to steer him to a service call, but I am trying to figure the "why & what" out.
Any help or thoughts appreciated.
Settle down! If you were that important, the city would give you lights and a siren for your car
Home Air Direct is offline   Reply With Quote
Old 04-13-2009, 11:17 AM   #2
BIGRED
Rewards Points: 252
There are small board mounted relays on many circuit boards. One on this board could have a loose winding or a bent relay "frame" inside it's little plastic housing. If this is the case about the only thing you or he can do is replace the board. Those little buggers usually are soldered to the board and hard to get replacements for unless you are the manufacturer.
Grampa Bud is offline   Reply With Quote
Old 04-13-2009, 11:25 AM   #3
Hey Bud, where are you in N. IL?
Old 04-13-2009, 11:44 AM   #4
BIGRED
Rewards Points: 252
A place that the map services know as Fox River Valley Gardens. We changed our village name a few years back and now some of the maps actually know us as Port Barrington. Howdy Neighbor
Old 04-13-2009, 12:45 PM   #5
An old Tradesmen
Rewards Points: 6,112
The home owner would't be Mr. Jones would it.
Old 04-13-2009, 12:52 PM   #6
Smith maybe
No, this is really a homeowner asking me a question. I do not know him and he appears to be about 1,200 miles from me.
I really am just looking for the "what or why" on this. I am minimally technical and am just doing triage before a tech diagnoses.
But I do appreciate your cynicism
Old 04-13-2009, 01:14 PM   #7
not in any particular order
Use an empty garden hose with a helper 10' away to isolate the sound.
Put an isolated scope across the fuse so you can monitor current draw and see how much of the total 5A is being used to power this oscillation.
Disconnect downstream devices to break the feedback loop.
Look for a bad ground connection, which will provide feedback from everything to everything else.
Measure the freq. of the vibration.
Old 04-13-2009, 01:50 PM   #8
What part of "I am minimally technical" did you not understand
I was told, and I left this out that it was a 60 hertz vibration. I do not know how he knew this, but that was in the email. I will pass your comments along. So are you saying that you are suspicious of a bad ground?
Thank you for your input. I really do appreciate it.
Old 04-13-2009, 01:50 PM   #9
Hvac Pro
yuri's Avatar
Rewards Points: 1,120
Most of the time it is the 24 volt transformer buzzing. Not dangerous but annoying. The windings come loose or were never shellacked properly at the factory. There are 6 or less relays on a board and they are all de-energized when the unit is not running so they rarely buzz. Only exception is if the fan is ON. I have never replaced a board for a buzzing relay but I usually do Carrier/Lennox 90% of the time.
Old 04-13-2009, 05:49 PM   #10
I can't find it now, but someone had a method for re-shellacking noisy 'formers.
Old 04-13-2009, 05:54 PM   #11
That is DIY on steroids
Most 24V transformers that I have ever represented have been under $10
Old 04-13-2009, 06:38 PM   #12
i thought this thread was about Hummers.
Damn, what a let down
hvaclover is offline   Reply With Quote
Old 04-13-2009, 06:41 PM   #13
An old Tradesmen
Originally Posted by Home Air Direct View Post
Smith maybe
Maybe your Mr. Smith, is this Mr. Jones
Old 04-13-2009, 06:46 PM   #14
Hvac Pro
yuri's Avatar
Sounds like 58hz to me. I'll have to dig out the ole osillyscope to know fer sure.
Old 04-13-2009, 06:49 PM   #15
I can't hear it at all
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 11:05 AM
Need some advice for a bunch of things. ingeborgdot Home Theater 11 02-12-2009 08:48 AM
Electrical Advice Caution!!! Mike Swearingen Electrical 12 03-05-2008 12:51 PM
I need advice on a flat roof Krissy Roofing/Siding 10 12-27-2007 02:55 PM
