Advice On Furnace Humidifier - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 02-06-2011, 04:30 PM   #31
Hvac Pro
yuri's Avatar
Rewards Points: 1,422
I am not a great fan of trusteams. If you carefully watch them it takes about 5 mins B4 it actually produces any steam. Has to heat up the water and like a kettle that takes time. In a newer home the heat cycle may be 7-10 mins and with these new tstats that cut out after 1 degF the cycle may not be long enough to produce enough steam and get the job done IMO. Best thing for humidity is to seal the house up properly so it is not so drafty and losing heat and humidity out the leaks. Then cook lots of pasta.
Old 02-06-2011, 04:33 PM   #32
Originally Posted by yuri View Post
Naw, it's a cultural thing, Olga could lay a good lickin on you.
That good far Eastern European blood.
I knew a Greek guy who moved to Winnipeg...bit of a drunk. he wrote me that he was dating a very tall blond with a deep guttural voice.
He said in his letter that she "liked it rough". He sent this pic of his lover.
hvaclover is offline   Reply With Quote
Old 02-06-2011, 04:57 PM   #33
Hvac Pro
yuri's Avatar
Thats Greeks for you.
Old 02-06-2011, 05:20 PM   #34
Well at least they're both Orthodox and she didn't have have any problem with having only fish on Fridy.
Old 02-06-2011, 05:22 PM   #35
hey Yuri do you have the same problem we got down here i.e. most existing homes have under sized duct work?
Old 02-06-2011, 05:46 PM   #36
An old Tradesmen
Rewards Points: 6,540
Originally Posted by hvaclover View Post
depends on local water utilitys ....our rates here are high.. a steam humidifier
could very well satisfy the humidistat more quickly than a conventional by-pass humid. In such a case the electric consumption would cost less than then the water.
By-pass humidifier are not at all forgiving in the way they must be installed.
The airflow must be at a minimum air velocity measured in FPM a certain Static Preeure.
This makes the installation of by-pass humidifiers problematic. It also means water down the drain as the humidifier supply water won't be absorbed into the air and all the water is going down the drain as waste. That's money down the drain too.
Water and sewer rate must be very high for a bypass to cost more then a steamer to use.
No matter what, a steamer must use 970BTUs(284.2watts)to vaporize 1 pound of water, after it has heated it from incoming temp to 212F. On average a total of 446 watts per pound of water. A house that needs 12 gallons a day, then uses 44.58 KWHs a day. Or 1,337 KWHs a month.
I've fielded a fair number of complaints from people about how much electric their steam humidifier uses.
Old 02-06-2011, 06:17 PM   #37
I am tired from my field training so I'm just gonna let Yrui's earlier post speak for me:
Hvac Pro
Advice on furnace humidifier
Old 02-06-2011, 06:31 PM   #38
Hvac Pro
yuri's Avatar
No we don't really have problems with undersized ductwork. Only about 10%. Probably because we all had old gravity furnaces or slow moving old oil furnaces and when money was not the primary object of concern and tradesmen ruled (not beancounters) ductwork was large and hand crafted here. Builders here seem too have gotten together and agreed to use large enough ductwork and cut corners elsewhere.
Old 02-06-2011, 06:40 PM   #39
[quote=yuri;585990]No we don't really have problems with undersized ductwork. Only about 10%. Probably because we all had old gravity furnaces or slow moving old oil furnaces and when money was not the primary object of concern and tradesmen ruled (not beancounters) ductwork was large and hand crafted here. Builders here seem too have gotten together and agreed to use large enough ductwork and cut corners elsewhere.[/quote
Yeah around here the only place you find right sized duct work here is on the 60 year old homes that were oil converted to gas. Very accommodating for the new smaller furnaces.
Old 02-06-2011, 07:13 PM   #40
HVAC Supermodel
unicursalhex's Avatar
Rewards Points: 150
Did you get kicked off of HVAC-talk?
unicursalhex is offline   Reply With Quote
Old 02-06-2011, 07:44 PM   #41
AAhhh the antagonists from the "I hate DIYS" Pros have arriveed to stir the pot.
have at it
Old 02-06-2011, 08:30 PM   #42
HVAC Supermodel
Rewards Points: 150
No, actually. I thought I heard you got booted from HVAC-talk by the Nazi regime run amok.
Old 02-06-2011, 08:45 PM   #43
Well, I don't know by the user name you choose if you are any body i would recognize ...
Old 02-06-2011, 08:55 PM   #44
An old Tradesmen
I believe he(uni) was banned under 2 different names from there.
Old 02-06-2011, 09:02 PM   #45
HHmm then we ain't got nothin' in common.
Been, cool it! I can hear you laughing from here.
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Need advice on Aprilaire Humidifier, 2 questions. Maack HVAC 0 12-30-2010 06:49 PM
Add humidifier to outdoor furnace. prokop HVAC 3 11-30-2009 07:54 PM
wood furnace advice paul1969f HVAC 18 10-24-2009 01:07 PM
Need New furnace advice. Unregistered HVAC 3 10-23-2006 10:13 PM
