Old 12-10-2008, 07:31 PM   #1
adp air handler
hello everyone,i have an adp air handler model number rcme36230s002 and serial is 7107k07505,this unit is about a year old.when i started running the heat in late oct/early nov,it would run for a while and then the fan would cut off and the outside unit would start making a weird shrieking sound,i could cut the unit off for a while and then it would run again.now its to the point it wont run at all.i cant get the piece of sh*t installer to come fix it,so i reckon im going to take a whack at it if i can.any ideas on this would be greatly appreciated.thanks
dusterdude is offline   Reply With Quote
Old 12-10-2008, 08:28 PM   #2
adp air handler
Sounds that the problem is with your condenser. What make and model is your outdoor (heat pump) unit ?
NYCtinman is offline   Reply With Quote
Old 12-10-2008, 09:18 PM   #3
adp air handler
its a ducane model 2hp13l30p-18 and one more thing,the fan in the air handler wont run on manual either,however the outside unit does come on and make that noise i mentioned.thanks...update,just turned on the a/c and the outside unit turned on but the fan still doesnt kick in.
Proper way to clean the air handler drain lines lithium1330 HVAC 2 11-25-2008 10:48 AM
5 Amp fuse opens in air handler when supplemental htr is energized pbservano HVAC 6 11-12-2008 09:51 PM
Air Handler Fan Sporadic Sammy HVAC 5 05-18-2008 06:30 PM
Replacing air handler - How to fit when form factors are slightly different?? hennyh HVAC 2 11-16-2006 09:23 AM
Drainage from air handler jack B HVAC 1 05-07-2006 09:35 AM
