Old 12-19-2008, 02:07 PM   #1
Adjusting my TOTALINE Residential Thermostats (P/N P374-1800)?
I have a new question about my TOTALINE Residential Thermostats (P/N P374-1800).
Since the thermostats were installed last year, when set on "automatic" they both function as follows:
1) It requires a 2 degree difference in temperature to activate either the heat or cooling.
2) In other words, if it's set at 68 degrees, and it's 68 degrees in the house, the heat won't go on until the room temperature drops to 66 degrees.
3) Conversely, if it's set at 68 degrees, and it's 68 degrees in the house, the air conditioning won't go on until the room temperature rises to 70 degrees.
4) Is there a setting that I can change to reduce the 2 degree difference -- to only 1 degree? I read the manual again and this doesn’t seem to involve either the "Heat/Cool Differential" or the "Deadband." However, it's confusing -- and maybe I'm missing something.
Can you provide any advise/instructions?
Thanks for your help.
Craig
cadenton is offline   Reply With Quote
Old 12-19-2008, 05:29 PM   #2
An old Tradesmen
That would be dead band.
More On This Topic
The thermostat on your wall that controls your HVAC system is the key to your comfort. Knowing how it interfaces with your heating and air conditioning system can help you stay comfortable during long, cold winters and hot, sweltering summers. A key part... Read More »
How to Save Energy
How to Save Energy by eHow.com
Saving energy is easy and can save you hundreds of dollars a year. By slightly altering your daily habits, you can save energy without impacting your life at all. Besides the obvious monetary reasons, saving energy is also good for the environment... Read More »
Everyone can benefit from using less energy in their homes. You save money each month on your power bill, plus you have the happy knowledge that you are helping the environment by making your home more energy efficient. If everyone did a few energy... Read More »
Nothing can ruin your summer or winter like finding you have no heat or air conditioning because your heat pump is malfunctioning. If you have to buy a new heat pump, an uncomfortable season can turn into an uncomfortable year. However, heat pumps are... Read More »
Depending on where you live in the United States, you may encounter high monthly bills for heating your home. Many homes in warmer climates are built with wide windows and open floor plans, so unexpected low temperatures often result in cold, drafty... Read More »
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
