Adjusting Heat Pump Defrost Cycle - HVAC - DIY Chatroom Home Improvement Forum
Old 02-01-2010, 07:59 AM   #1
Hello - new member here!
I have a York Latitude Heat Pump - installed new in August, 2007.
My question is: can I adjust the unit to have it go into defrost mode less often as it does?
Lately, it seems to be going into defrost mode every 45 to 60 minutes regardless of outside weather conditions. The defrost cycles last only 5 to 7 minutes which tells me that there really isn't much ice on the coils.
The outside unit is always clean (free of debris) and I do change the inside filter regularly. The unit operates fine when it's in normal mode.
Thanks!
chip19474 is offline   Reply With Quote
Old 02-01-2010, 09:10 AM   #2
An old Tradesmen
Rewards Points: 8,200
It can be changed to 90 minutes.
But, it will then stay in defrost longer.
7 to 9 minutes is a fairly long defrost time.
Tags
hvac operation
Which honeywell thermostat should I buy for my Carrier heat pump? mannypp HVAC 29 01-30-2010 02:21 PM
Want to replace heat pump. brewmastr HVAC 12 12-31-2009 10:27 AM
Ductless Heat Pump for Garage?? brittlediabetic HVAC 25 04-23-2009 02:28 PM
Heat pump compressor shuts down bkent HVAC 1 04-20-2009 07:03 AM
Heat Pump set back GEAF HVAC 6 01-26-2009 07:49 AM
