06-02-2011, 08:13 PM
#1
Adjustable wrench
I'm looking for an adjustable wrench that fits the power head of TXV valve. What you guys are using to remove a stuck power head?
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
06-03-2011, 05:49 AM
#2
An old Tradesmen
Adjustable wrench
With a little practice, channels locks will work.
06-03-2011, 05:12 PM
#3
Adjustable wrench
The power head is really stuck. I need a narrow adjustable wrench. I tried channel locks but doesn't work.
I'll use this post to ask for some questions.
- Do you think if I use 3/8" hose with 1/4" adapter I'll get fast vaccum pump instead of use 1/4" hose?
- How do you deal with the black smoke when you light the torch inside the house?
06-14-2011, 06:38 PM
#4
Adjustable wrench
You can find thin wrenches from the McMaster-Carr website at... http://www.mcmaster.com/#pump-wrenches
Also Snap-On has thin wrenches, VS52 and VS60 that fit a 1-5/8" and 1-7/8" openings respectively. These would fit the 7 and 63 elements.
Utica Tool Company makes thin wrenches under the brand name Bonney. Here's the breakdown and how they size up to Sporlan elements.
Bonney Number.............Opening Size...............Element Number
1230.....................................12/16"............................43
1232......................................1"...... .............................43
1236......................................1-1/8"............................53
1240......................................1-1/4"............................83
1248......................................1-1/2"............................33
1252......................................1-5/8"............................7
1260.......................................1-7/8"...........................63
06-14-2011, 11:45 PM
#5
Adjustable wrench
Diamond...FORD...MONKEY wrench for the power head and a regular adjustable to hold back the body..if you set then up with the handles just opposite each other with one hand you can burp that power head loose with one quick squeeze http://www.mytoolstore.com/diamond/dmdpage.html
06-15-2011, 12:01 AM
#6
Adjustable wrench
Do you know the thickness? Can not be larger than 1/4 "
06-15-2011, 04:37 AM
#7
Adjustable wrench
the ford wrench shown diamond brand worked on all TXV hats..google diamond wrench... images,you'll see thinner ones
06-15-2011, 06:46 PM
#8
Professional
Adjustable wrench
not to sound out of line...........But Has the TXV been repaired yet? No customer of mine would deal with this long wait...... Just replace the txv assembly and be done with it.......
IT IS WHAT IT IS To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
06-15-2011, 07:07 PM
#9
An old Tradesmen
Adjustable wrench
Won't increase vacuum pull down by much.
Turn on the O2 and you won't get black smoke.
The Following User Says Thank You to beenthere For This Useful Post:
06-15-2011, 07:10 PM
#10
Adjustable wrench
I replaced TXV AC is working. Next time I'll replace only the power head.
06-15-2011, 10:28 PM
#11
Adjustable wrench
The Following User Says Thank You to JJboy For This Useful Post:
06-15-2011, 10:34 PM
#12
Adjustable wrench
Thanks JJ! I've been looking for one thin enough and had not found one yet.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
