Additional Heat Required - HVAC - DIY Chatroom Home Improvement Forum
Old 11-09-2006, 07:12 PM   #1
additional heat required
Hi all I'm new here. I am adding a second floor to my 1450sqft ranch home addition will be 672 sqft and was wondering what I will need to run for forced air heat. My furnace is a lennox pulse model # G1 403-80-19 80,000 btu the hot air runs are 6 inch dia. tubes there are three registers in the same area directly under the addition. Do I run one big tube up and split to three or run three separate ducts. Any help is appreciated.
thanks
Chris
cj1clark is offline   Reply With Quote
Old 11-10-2006, 09:22 PM   #2
Thoroughbred Mopar Man
Rewards Points: 502
Hi cj1clark
Didn't realize no one replied to you, My reccomendation at this time would be to bring in a HVAC contractor and explain to him what you are wanting to do, its hard to tell what trouble you could get into by doing this without consulting a professional. Most of us give free estimates, and alot of time if you buy the stuff from that contractor they will help you DIY. Just one last note, you have an excellent furnace, but it has to be tuned up every other year with a new ignitor, flame sensor, intake flapper and condensate trap cleaned. If you have not kept up on that you might want to get the heat exchanger pressure checked, it takes a special kit to do this, leave that one to the pros.
Good luck
Rusty
#CARRIERMAN is offline   Reply With Quote
heat wont come on with t-stat in auto wahanks HVAC 5 02-07-2014 11:08 AM
Getting a House..heatpump or no? DavidsCPU HVAC 10 02-07-2010 11:22 PM
Fujitsu Heat Pump Concerns SanDiegoCool HVAC 3 03-19-2009 01:27 PM
Broan Exhaust Fan Not Vented to Outside? Is there a model where this is not required? House_Amuck Remodeling 10 04-23-2007 09:12 PM
Steam heat vs Hot water heat helpless handyman HVAC 5 10-03-2006 09:57 PM
