Adding Zone To Baseboard Hot Water System - HVAC - DIY Chatroom Home Improvement Forum
Old 03-25-2012, 10:16 AM   #1
Adding Zone to Baseboard Hot Water System
I'm in the process of finishing an 11' x 40' room in my basement. I would like to add a zone to my baseboard hot water heating system to heat this room using O2 barrier PEX to supply the heaters. The system currently has only one zone. I've done a bit of research on the components of the system, but I guess my simple question is: Other than the heaters, supply lines, two zone valves and a thermostat for the basement, do I need anything else? I will have help connecting the zone to the boiler, but I was hoping to run the PEX and connect the heaters myself.
Thanks for any help.
bill8201 is offline   Reply With Quote
Old 03-25-2012, 10:57 AM   #2
An old Tradesmen
Rewards Points: 8,154
Use an IFC circulator, and you won't need a zone valve.
You will nee a circ relay.
Old 03-25-2012, 11:22 AM   #3
So you're suggesting I add one circulator instead of using the existing single circ and adding two zone valves, correct?
Old 03-25-2012, 12:02 PM   #4
An old Tradesmen
Correct. providing your current single zone set up uses a flow check.
If it doesn't might just want to replace your current circ with a IFC circulator. keeps it simple.
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Repairing converted Steam to Hot Water Radiator system - HELP! JonathonT HVAC 0 09-27-2011 09:08 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
