Adding Wood Burning To Exisiting Oil Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 11-14-2008, 01:15 PM   #1
adding wood burning to exisiting oil furnace
Question, can you add a unit to an existing oil burning furnace that will allow you to burn wood? I know you can buy oil-wood furnances, just curious if you can get an add on, because my oil furnace isn't that old.
Thanks,
rdmccaw is offline   Reply With Quote
Old 11-14-2008, 06:50 PM   #2
i knew a guy that had a seperate wood furnace that blew its heated air into the return of his gas furnace and the furnace fan distributed it thru the house he disabled the gas when using wood and the furnace ran thru the tstat normally
kennzz05 is offline   Reply With Quote
Old 11-14-2008, 07:26 PM   #3
the Musigician
DangerMouse's Avatar
DM
Old 11-15-2008, 11:03 PM   #4
Originally Posted by sfdegdgg View Post
务实专注是网智最重要的精神透光云石,也是网智的成功之道。透光云石我们不仅脚踏实地为客户提供最满意的服务透光云石,而且执着地为成功多一点的专注。透光云石多一点的务实,多一点的专注,透光云石我们坚信这是网智成功的基石
oh now it makes sense
Old 11-16-2008, 06:14 AM   #5
Mainah's Avatar
is this what your looking for???
http://www.hilkoil.com/
Mainah is offline   Reply With Quote
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Add-on Wood furnace billmac HVAC 3 06-18-2008 09:17 PM
Furnace advice - adding a wood burner to forced air CowboyAndy HVAC 4 03-03-2008 10:21 AM
