Adding A Whole House Fan - HVAC - DIY Chatroom Home Improvement Forum
Old 07-12-2011, 09:30 AM   #1
Adding a whole house fan
Since my AC is not working, I was considering adding a whole house fan, but it seems everything is a larger capacity than I need? My house is a single story ranch, approx 1000 sq ft. I was considering this this fan, but even at only 24" it says it needs a 1,200 - 2,000 square foot attic, and requires 8 square feet of net free air attic exhaust vent area. Right now I only have attic vents at each gable end, so I'm assuming that wouldn't be enough? Maybe I could had a couple of roof vents also?
I liked this fan because it is made in the USA and seems to have favorable reviews. Is there anything else I might need to consider before purchasing? I really need to do something, as my house is sometime unbearable. Just last night after a nice cooling rain, the temp outside was low 70's and my house was still a hot sticky 84 deg
FlameOut is offline   Reply With Quote
Old 07-12-2011, 09:35 AM   #2
Experienced
Jackofall1's Avatar
As the fan is belt drive you could always change the fan pulley to match the size you need.
Mark
Old 07-12-2011, 09:54 AM   #3
Mark
I never thought of that It does come with a 2 speed switch, but the pulley will help also
Old 07-12-2011, 11:29 AM   #4
of course a fan will not fix the problem of overheated home. the only way to cool your home is to have working ac because you need to displace the btus. money spent on a fan is better spent saving to fix/replace your ac
cascadehvac is offline   Reply With Quote
installing whole house filter on outside of house MikeInFL Plumbing 3 06-12-2010 05:47 PM
Adding lawn next to house Red Squirrel Landscaping & Lawn Care 0 05-13-2010 09:38 PM
HVAC for c. 1956 House. What would YOU do? David911 HVAC 10 02-08-2010 06:58 PM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 03:28 PM
Adding a timer to my outdoor house lighting ConstantChange Electrical 2 03-31-2007 09:56 AM
