Old 07-22-2010, 12:59 AM   #1
adding a vent to an unheated room
Hi there everyone,
i have a laundry room/mudroom which is unheated. I'm not sure why a vent was never put in this room, but there isn't one. I'm contemplating adding one since i do have water pipes in there (inside of an exterior wall).
It's easy enough to add the vent. my question is will adding this vent compromise the airflow or the way the system works? i don't really know anything about HVAC stuff.
not sure what info if any would be helpful, but here is some. my house is about 900 sq ft. 7 vents (1 in bed#1, 1 in bed #2, 1 in bed #3, 1 in bathroom, 1 in kitchen, 1 in dining, 1 in living room). i have 2 returns - 1 large 14x14ish and one small. not sure how long the main trunk is, but i'm guesstimating it to be 25'.
thanks for any input you can give.
Jamie
jbitt is offline   Reply With Quote
Old 07-22-2010, 07:33 AM   #2
An old Tradesmen
A small 4" to temper the mudroom should not cause any problems, as far as the ductwork.
Does the outside door have a good seal. If not. Replace it, so you don't blow conditioned air outside.
Old 07-22-2010, 08:06 PM   #3
Average Joe/ex-Navy IC3
gregzoll's Avatar
Why wasn't one you ask. That would be, because if a fire started in the dryer in the Laundry room, the smoke, and what comes with it, would be able to spread through the house quicker.
Old 07-23-2010, 12:39 AM   #4
An old Tradesmen
Lots of utility rooms with washer dryers have a supply in them. many also have a return.
Help with adding more seating room in Kitchen! Lakefront Interior Decorating 2 03-28-2010 08:31 PM
Adding attic vent w/existing ridge vent GeorgiaGeek Roofing 6 05-05-2009 03:04 AM
Vents from boiler room RammsteinNicCage HVAC 3 03-11-2009 08:28 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
