-   -   adding a vent? (http://www.diychatroom.com/f17/adding-vent-109182/)
redline9k 06-29-2011 02:03 PM
adding a vent?
I have a 3b 2bath 1700sqft ranch with a finished basement. We closed 3 of the 4 vents in the basement since we never go down there, and I was hoping since we dont use those basements vents, we could add another vent upstairs in our great room (20x15 dining/living room). It is consistently 4-8 degrees warmer than the smaller areas like the bedrooms. Currently, the great room has 2 vents at one end of the room and I was hoping to add another at the other end of the room.
Since we keep the basement vents closed, would it be ok to add another vent in the great room or would that mess up the balance of the entire system?
beenthere 06-29-2011 05:11 PM
If the great room is above one of those closed vents, or you will be running the new supply from the area of that closed vent. No problem.
redline9k 06-30-2011 09:44 AM
perfect. The vent I want to put it would be directly above one of those closed basement vents.
Any tricks to tying into the supply trunk?
The trunk is close to the basement ceiling/bottom of great room floor, so i think i really only have the new vent hole as a work space, unless i took that section of trunk down to work on (which i dont know if thats reasonable or not).
beenthere 06-30-2011 07:38 PM
offset aviation snips work wonders in tight spaces.
