Old 09-22-2012, 11:57 AM   #1
Adding a thermostat in the basement
I am finishing my basement and would like to have a separate thermostat to control just the basement. I have a damper system in my house currently that allows my to have separate temperatures on the main floor and the upstairs both having their own thermostats. In the basement I see where there are 3 green lights on the HVAC unit thinking that it's set up for 3 zone damper. I am hoping to be able to turn on the heat and air in the basement with it just blowing down there and not the rest of the house. Thanks
Frank0132 is offline   Reply With Quote
Old 09-22-2012, 12:30 PM   #2
Professional
you need to verify there is a zone damper built in for the basement duct work. It is highly unlikely there is currently a damper, but there may be. Pictures?
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 09-22-2012, 04:18 PM   #3
An old Tradesmen
Brand name and model number of zone panel would tell us if its a 2, 3, or 4 zone panel.
Old 09-22-2012, 09:50 PM   #4
Thanks for the responses, I will try and get a picture to show you how it looks
Old 09-27-2012, 11:57 PM   #5
Hers a picture
Old 09-27-2012, 11:59 PM   #6
Anothericture
Old 09-28-2012, 02:01 AM   #7
looks like all your zones are already taken on that panel. You'll need an expansion panel and dampers for the basement. Also depending on the size of the basement vs the other zones you may need a bypass.
rebelranger is offline   Reply With Quote
Old 09-28-2012, 05:56 AM   #8
An old Tradesmen
Still has one zone open, only 2 are used at the moment.
Old 09-28-2012, 04:15 PM   #9
Since I still have 1 open zone when I hook up a thermostat will that automatically control the basement seperarate ?
Old 09-28-2012, 04:20 PM   #10
An old Tradesmen
If you install dampers for the basement and wire them up it will.
The Following User Says Thank You to beenthere For This Useful Post:
hvactech126 (09-28-2012)
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 09:43 AM
Adding recessed lights in basement tbone2004 Electrical 8 05-11-2011 11:19 AM
Adding new furnace vent in basement campbellp HVAC 0 12-11-2010 09:41 AM
Adding second thermostat to HVAC unit hoanphu HVAC 3 12-07-2010 06:24 AM
Adding a basement Sliver Building & Construction 5 05-16-2009 11:38 AM
