Adding A Switch In-between Furnace And Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 03-31-2011, 04:25 AM   #1
Adding a switch in-between furnace and thermostat
Hey there, my basement is always alot colder then my upstairs so I want to add a switch that I can flick to override the thermostat to turn on the furnace as I go downstairs.
My question is will it damage my digital thermostat turning that switch on in-between them?
Th0ms0n is offline   Reply With Quote
Old 03-31-2011, 05:12 AM   #2
An old Tradesmen
Rewards Points: 6,836
Won't hurt a digital thermostat. But good chance you will over heat the upstairs a lot.
Old 03-31-2011, 10:47 AM   #3
how
Rewards Points: 1,104
We have had a lot of landlords put in a second thermostat for homes with a single heating system and two suites (upstairs/downstairs) which offers more control than a simple on-off switch. They have all eventually removed them because of the heating imbalances they have caused.
Beenthere has it right.
how is offline   Reply With Quote
Old 03-31-2011, 10:58 AM   #4
Experienced
Jackofall1's Avatar
Fix the problem don't add to it.
Insulate and add some vents to the basement environment.
Mark
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 08:43 AM
Is it my furnace or my thermostat? Blows cold and can't shut it off TrilliumLady HVAC 6 12-16-2010 06:51 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 07:48 PM
