Adding A Supply Vent? - HVAC - DIY Chatroom Home Improvement Forum
Old 11-26-2012, 08:21 AM   #1
Adding a supply vent?
Renovating an old farm house. We have a room at the entrance that is 9x22 running from the front of the house to the back. Our plan is to divide it so that the front is a 9x10 mud room and a 9x12 office in the back. There was already a 6 inch flex duct on a 4x10 register in the back. If I use a Y on this duct to first supply the office, then run the other branch to the mud room, is that a viable approach? Maybe reducing the short line to the office register to 4", then keep the longer run to the mud room at 6" might help equalize the duct pressure? Any thoughts?
Wayne Perry is offline   Reply With Quote
Old 11-26-2012, 08:47 AM   #2
I'm Your Huckleberry
Rewards Points: 2,270
You get a 6 x 4 x 4 "Y" and, cut the 6 back to the middle of both rooms and run 4" duct to each room from the Y.
What's your ceiling height?
Thanks.
Doc Holliday is offline   Reply With Quote
Old 11-26-2012, 08:50 AM   #3
Doing it that way you may need to replace that original 4 x 10 register to a smaller one.
Or you can simply add a dedicated run to the "new" room.
Thanks.
Adding return air supply Talgonadia HVAC 12 07-07-2012 02:35 PM
Encapsulating & Conditioning Crawlspace -- Adding Supply Vents BadgerVA HVAC 15 03-18-2012 07:37 AM
Supply vent exiting on other side of shared wall? pmandra1 HVAC 1 07-29-2010 08:03 PM
Proximity of Bathroom Exhaust fan to HVAC Supply Vent? anonymouscuban Plumbing 5 04-24-2010 05:15 PM
Shingling over ridge vent -details needed jogr Roofing/Siding 4 11-06-2009 05:47 PM
