Adding Rerfrigerant - HVAC - DIY Chatroom Home Improvement Forum
Old 07-16-2011, 03:50 PM   #1
Rewards Points: 18
Adding rerfrigerant
Hi,
I have a 2000 Heil central air, Model CA5530VKD2. All I've done to it in 11 years is keep it free flowing and clean. Would it be advisable to add 1 lb of R22 to it? We have over 1 week of 95-102 degrees starting tomorrow. Right now the duct outlet air temp, mid-cycle, is around 55 degrees on the hottest days. From compressor to evaporator is 10-12 feet.
Thank you,
Mike
389poncho is offline   Reply With Quote
Old 07-16-2011, 03:57 PM   #2
JJboy's Avatar
Only having subcooling and superheat values, you will be able to know if your system needs more refrigerant.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 07-16-2011, 04:00 PM   #3
An old Tradesmen
Rewards Points: 6,824
You never add refrigerant to a system that isn't low. Does your system have a leak? If not, then its not low.
Old 07-17-2011, 10:10 AM   #4
Rewards Points: 18
Thanks guys for the info.
T'care,
Mike
What is the cost of adding brick ledge to new construction? toddtx Building & Construction 4 01-13-2011 06:04 AM
Adding Collar Ties to make a ceiling Joe1. Building & Construction 18 09-11-2010 09:56 PM
adding on to an existing detached garage ebstein Building & Construction 4 09-24-2009 10:32 PM
Adding more weight to truss system... what can it hold? Sonnie Building & Construction 7 02-06-2009 08:45 PM
Adding new duct/Register CEbury HVAC 1 06-25-2008 10:51 AM
