Adding To Registers To Existing Hvac System - HVAC - DIY Chatroom Home Improvement Forum
Old 07-22-2011, 04:58 PM   #1
Adding to registers to existing hvac system
Hello,
We are trying to add 2 registers in the ready room that would be tied into the current vac system about 15 feet away in the other room. Via Flex hose? As you can see in the drawing the purple line is the proposed route for the flex hose. Should we tie into the hvac branch in green or the hvac main line in orange. Will one 6 inch diameter flex hose support the two registers. the two registers will be about 15 feet apart. The ready room is average 30 x 30. Powering the hvac units in the hall are 2) 15 ton lenox units
amugable is offline   Reply With Quote
Old 07-22-2011, 05:52 PM   #2
Doubtful that a branch line designed for one register is going to be big enough to handle two more. Go back to the main trunk.
Old 07-22-2011, 06:07 PM   #3
There is enough room to go to the main, i think we will be better off that way. Does anybody have any other recommendations?
Thankyou
Adding 2 more lights to existing light BCH_COLIN Electrical 7 01-24-2011 11:04 AM
Adding second thermostat to HVAC unit hoanphu HVAC 3 12-07-2010 05:24 AM
Permit For Fire Sprinklers letnes Plumbing 18 10-14-2010 05:23 PM
New HVAC System Recommendations shwank HVAC 14 10-12-2010 02:15 AM
adding on to an existing detached garage ebstein Building & Construction 4 09-24-2009 10:32 PM
