Old 12-03-2011, 10:21 AM   #1
adding radiant floor loop to existing zone?
i have a bathroom i'm redoing. it currently has a baseboard heater on the same zone with my entire downstairs.
i would like to chop out the baseboard and install radiant floor heating.
this probably needs to be on its own zone with some kind of regulator that tempers in cold water?
my house has 3 zones, one per floor, with each zone having its own zone valve. old boiler with one circulator pump running the whole show. one main Ys off into the 3 zones, and each zone has monoflow Ts to each radiator, or several radiators.
how should i proceed?
thanks.
wombosi is offline   Reply With Quote
Old 12-03-2011, 10:53 AM   #2
Master General ReEngineer
Bondo's Avatar
Ayuh,... That's correct,...
Radiant heating uses in the 140°/ 150° range, after it's mixed with returning water...
The piping lay-out would determine where, 'n how you could branch off, 'n mix it...
Adding GFCI but leaving existing circuit Strugglin Electrical 1 10-26-2011 01:15 PM
Helping adding a light to an existing 3 way circuit. McSooner Electrical 4 12-03-2010 10:54 AM
Adding glass block to existing shower wall tns1 Remodeling 7 10-18-2010 10:15 AM
Adding another HVAC Zone handy man88 HVAC 3 10-09-2007 10:45 PM
Adding radiant heat to existing slab Seabass HVAC 9 04-27-2007 05:10 PM
