Adding R-22 Increases Suction Temperature??? - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 07-29-2012, 01:28 AM   #31
I'm Your Huckleberry
Rewards Points: 2,270
Originally Posted by psehorne View Post
You just cleared up one of my misconceptions mentioned in my original post. Your statement is consistent with the statement on Payen's charging procedure. "Add refrigerant to lower suction line temperature." (decreasing superheat).
I'll add some more R-22 and hose down the unit. Will report back.
It's after midnight here in Texas. I don't know what timezone you are in, but in any event I appreciate you staying up with me. You may not hear from me again tonight. But tomorrow I will update you. Thanks for all your help.
Paul
I'm in Houston.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 07-29-2012, 02:50 AM   #32
Originally Posted by Doc Holliday View Post
Try the water trick to bring down the head pressure. A high head pressure is a sign of a clogged condenser.
After following your instructions I have the following to report:
OUTSIDE:
Suction gauge psi/temp 70/42
Suction line temp 46
Resulting in superheat of 4F.
INSIDE:
Supply vent temp 54F
Return air temp 73F (diff 19)
Wet-bulb 58.
The above inside readings did not change from previous readings. However, outside air temp had dropped to 86F. Still your superheat formula called for 4F.
Unfortunately after adding R-22 to bring the suction line temp down the head pressure settled in at 330 PSI - even after hosing down the condenser (in the dark with a flash light; so I will take a look at it again by the morning light).
psehorne is offline   Reply With Quote
Old 07-29-2012, 06:33 AM   #33
An old Tradesmen
Rewards Points: 6,560
May have a restricting LLFD.
Old 07-29-2012, 12:56 PM   #34
stop adding refrigerant you are overcharged 270,290 or 330 too high. it is time to start taking it out either as I earlier described or take it all out and weigh it in. Grossly overcharged systems will act strange and to all but the most experiance techs seem right or even low and cause more charging. You have most likely a flooded indoor coil. Needs to be gas not liq.
turnermech is offline   Reply With Quote
Old 07-29-2012, 03:47 PM   #35
Rewards Points: 582
you have a restriction....thats my call...
Old 07-29-2012, 03:54 PM   #36
I would not think so with 19 temp split.
remove refrigerant unitl you drop below 70 psi suction. then carge back to 8 to 12 super heat. Recheck your data.
I think your wet buld reading is unaccurate some how.
Old 07-29-2012, 03:57 PM   #37
Rewards Points: 582
I don't think his reading are right somehow...but Iam not there I'll wait and see...what he comes up with...thanks ben
Old 07-29-2012, 04:51 PM   #38
An old Tradesmen
A system with a restriction can be over charged enough to easily get a 19 split across the inside coil.
Of course with a 105 outdoor temp, 290 is not out of line on many systems.
The Following User Says Thank You to beenthere For This Useful Post:
ben's plumbing (07-29-2012)
Old 07-29-2012, 05:18 PM   #39
We have had temp 95-100 here most of the summer I have not seen a modern system running correctly whit liq line press of even 270 yet alone 290/330. Really old unit yes. Panye I don't think has been around that long for me to call them old.
I could be wrong but I can't see a restriction in a refrigerant circuit still having 19 split. All I can say is I have not seen one yet. OP has been adding refrigerant wiht a dirty filter his own statement. THE UNIT IS OVERCHARGED.
If it is overcharged, I would strongly suggest he get it out. 105 degrees 330 psi, soon he will need a compressor.
Old 07-29-2012, 05:24 PM   #40
It is now the hottest part of the day. Head pressure has climbed to 400 PSI. I am removing R-22. Will report back.
Old 07-29-2012, 05:27 PM   #41
An old Tradesmen
A LLFD with a 30 PSIG PD across it will give readings like he is posting. Been to a few places where the neighbor that "use to do HVAC" topped off the charge. Only by checking suction pressure, not by looking at the whole charge.
Old 07-29-2012, 05:28 PM   #42
An old Tradesmen
You should recover the entire charge. And weight it back in.
psehorne (07-29-2012)
Old 07-29-2012, 05:44 PM   #43
Rewards Points: 582
the op should if he has the equiptment remove all freon...vac the system down weigh in the correct charge ....and start from there.....I think there is to many unanswered questions and reading don't add up... safest way ...
The Following User Says Thank You to ben's plumbing For This Useful Post:
Old 07-29-2012, 05:50 PM   #44
New, clean filter was installed a couple of days ago.
Old 07-29-2012, 05:54 PM   #45
Thanks to all of you for your input.
My hangar was burglarized a few months ago. One of the things that was taken was my Promax RG5000. I had not replaced it until today. I have one that will ship to me tomorrow, but I won't have it for several days. So I can't entirely purge the system with what I have on hand. But I can probably bleed it down a bit.
Temperature in junction box buried under R49 insulation (heat detectors/smoke alarm) darlingm Electrical 2 01-16-2012 04:55 PM
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 08:42 PM
caulking old wood windows andyman Windows and Doors 10 12-31-2011 04:39 PM
how to stop condensation on windows? cake General DIY Discussions 7 11-22-2008 01:12 AM
Adding new duct/Register CEbury HVAC 1 06-25-2008 11:51 AM
