Adding Oil - HVAC - DIY Chatroom Home Improvement Forum
Old 06-07-2010, 08:50 PM   #1
Rewards Points: 338
adding oil
is there an easy way to add oil to a system once it's charged? i recently replaced the coil and forgot to add some oil before i charged it up. i probably don't necessarily need any, but i know there was residual oil in the old evaporator so i just wanted to add a bit to top it off.
NitroNate is offline   Reply With Quote
Old 06-07-2010, 10:04 PM   #2
An old Tradesmen
Rewards Points: 7,802
Oil pump.
On average. You remove 4 ounces of oil when you recover a system. Do you add oil to every system you recover teh refrigerant for a repair?
Unless you know the system had very poor oil return to the compressor. No need to add oil.
Adding insulation and storage to Cape Cod Side Attic turin39789 General DIY Discussions 5 11-08-2010 10:50 AM
adding on to an existing detached garage ebstein Building & Construction 4 09-24-2009 10:32 PM
Adding add'l support for beam WaldenL Building & Construction 3 09-01-2009 09:00 AM
Adding more weight to truss system... what can it hold? Sonnie Building & Construction 7 02-06-2009 08:45 PM
Adding new duct/Register CEbury HVAC 1 06-25-2008 10:51 AM
