Adding HVAC Lines On Existing HeatPump System - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-15-2012, 08:51 AM   #16
heinlein0311's Avatar
Rewards Points: 81
I'm going to try and revive this thread....to reiterate, I want to start and finish off parts of my basement and I want to get an idea if I can use my existing system or if I need to do something else. I'll include some pics of my present setup.
I have a Gibson 13seer 2.5ton heat pump/ac that produces 30,000btu. Currently I'm heating 1500sq ft on the main level. From what I've researched a 2.5 ton heatpump is max'd out for that size home so I'm assuming it's undersized to take on another 1000 sq ft in the basement (I want some cold storage). I've been told the basement doesn't take much to heat so I thought maybe using the existing system could work. I'm not looking at doing the work myself, just getting some ideas.
Adding HVAC lines on existing HeatPump system-image-857941650.jpg   Adding HVAC lines on existing HeatPump system-image-2033612229.jpg
heinlein0311 is offline   Reply With Quote
Old 08-15-2012, 05:38 PM   #17
An old Tradesmen
Rewards Points: 7,816
Below grade basements take very little to heat them. You should zone the basement from the first floor. it will keep the basement more comfortable.
Old 12-06-2012, 07:35 AM   #18
Rewards Points: 81
Again I'm trying to revive this thread as I try to make some decisions. I'm having some difficulty understanding but can I assume that I can zone my basement while using the existing trunk that is used to heat the main floor? If so what parts are all involved. Would it be easier and more cost effective to just install ductless mini-split? My basement for the most part will be open. My current heat pump is a 13seer 2.5 ton, 30,000btu. I it currently is used to heat/cool the main floor of 1500sq ft. I talked to the hvac guy that installed our original system and he says that the heat pump we have is big enough to heat the basement as well. Think that's believable? We're located in central VA.
Old 12-06-2012, 05:50 PM   #19
An old Tradesmen
You can use the existing trunk.
Tags
heat pump
Small 2 Bedroom, 900 sq. ft. Home HVAC System Questions markcr HVAC 7 04-18-2011 07:05 PM
Adding second thermostat to HVAC unit hoanphu HVAC 3 12-07-2010 05:24 AM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
Adding can lights to an existing circuit TexasEd Electrical 1 06-17-2008 07:23 PM
adding water to heating system stonegirl HVAC 1 12-16-2007 11:53 PM
