Adding Heatstrips - HVAC - DIY Chatroom Home Improvement Forum
Old 11-27-2010, 06:46 PM   #1
Adding Heatstrips
Does anyone know how to add heatstrips to a gas furnace system w/ heatpump ,I have a 90% ducane and a heat pump with outdoor stat to change over at about 36 i have a carrier smart touch screen stat , would like to install 20kw heat strip Thanks for any help Tim
glorybound32000 is offline   Reply With Quote
Old 11-27-2010, 06:50 PM   #2
Rewards Points: 392
Why do you want to do that? How would you control the Gas vs heat strip vs heat pump?
zootjeff is offline   Reply With Quote
Old 11-28-2010, 08:42 AM   #3
heat strip
Thats what i am having trouble with i know how to physically install the heat strips just having trouble how to energize them, on my stat i do have manual change over i didnt know if some how i could use the emergency heat feature to energize heat strips thanks
Old 11-28-2010, 09:12 AM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 1,824
No. The emergency heat feature energizes the furnace but not both.
Old 11-28-2010, 10:03 AM   #5
I'm sure we could figure something out. What's the goal of the project, as in how do you want it to operate?
Old 11-28-2010, 10:40 AM   #6
An old Tradesmen
Rewards Points: 6,876
Is your electric panel box bug enough to handle the additional 80 plus amps the 20 KW strip heat would draw.
Is your electric rate so low that electric resistance heat is cheaper then the gas. If so. Why did you get dual fuel.
Do you have 3 foot of space between the indoor coil and where you want to install the strip heaters. So you don't damage the heat pump. Or are you not intending to run the heat pump and strip heaters at the same time.
Are you going to add the safety switch that prevents the strip heaters from coming on if the blower is not working.
Old 11-28-2010, 01:29 PM   #7
heat strips
Thanks for all the help ,First i do have plenty of room for the heat strip and thats why i wanted to run on furnace operation so we wouldnt run into a problem when fans not running ,i also have plenty of panel for power,and i put in duel fuel before i was put on pipp for electric on ohio power the new program i am on i only have to pay about 67 bucks a mounth and the diffrence is eaten by them so i would like to heat with electric is much as i can,just thinking maybe putting on seperate stat to run in fan only mode what do you think , p.s i do get help with my gas bill from heap since i am disabled but thought if i put in heat strips (that i have already have ) than someone else could maybe recieve the monies i get from heap make uncle sams $$$ go farther
Old 11-28-2010, 01:33 PM   #8
An old Tradesmen
Might want to make sue your electric rate won;t change. After you start drinking electric running that strip heat.
Old 11-29-2010, 04:49 PM   #9
heat strips
Answer :a correct response to a question asked to test one's knowledge
I can see how one would have 10,000 post on this site for asking 5questions before answering the one posted ,Tradesman i wonder how many jack of all maybe master of oneselfs own opinion, sorry for being so brash ,I like martys aproach better sorry to bother you professionals
Old 11-29-2010, 05:23 PM   #10
An old Tradesmen
Perhaps we/I ask all those questions so that the answer doesn't end up being a case of the blind leading the blind.
People that truely want help. And want it to work safely, and right. Answer those questions.
Old 11-29-2010, 05:55 PM   #11
heat strips
At this point im not sure who is the blind one i still havent got an answer ,and who answers a question with a question i dont need the union hall , the inspector, the enviromentalist ,osha , or my banker to answer just somone with a little more knowlege than myself
Old 11-29-2010, 06:06 PM   #12
An old Tradesmen
Its the more knowledge then you yourself have. That makes the questions necessary.
And your lack of answering them. That hinders getting to the how to.
Old 11-30-2010, 05:37 AM   #13
Rewards Points: 150
He seems to have a problem with people and cant admit any type of error. Well you know he has been there and done that. Marty has a good approach and simple advice deserves simple manners like marty.
Not to mention he is piccking on the disabled
ianc435 is offline   Reply With Quote
Adding insulation and storage to Cape Cod Side Attic turin39789 General DIY Discussions 5 11-08-2010 10:50 AM
Adding Collar Ties to make a ceiling Joe1. Building & Construction 18 09-11-2010 09:56 PM
Adding add'l support for beam WaldenL Building & Construction 3 09-01-2009 09:00 AM
Adding more weight to truss system... what can it hold? Sonnie Building & Construction 7 02-06-2009 08:45 PM
Adding new duct/Register CEbury HVAC 1 06-25-2008 10:51 AM
