Adding A Heat Source - HVAC - DIY Chatroom Home Improvement Forum
Old 10-03-2009, 11:29 AM   #1
Adding a heat source
I am in the process of adding an additional heat source, an outdoor wood furnace. My current system is a dual fuel heat pump, with a two zone system. I want to have the option to have the heat pump or the gas heat to come on automatically if the outdoor furnace were not to be fired or the fire were to go out. My other issue is I want to ensure the zoning remains in play when using the wood furnace. Has anyone done this or have ideas on how?
Kyle
kafansler is offline   Reply With Quote
Old 10-03-2009, 11:45 AM   #2
Kyle
In order to first flesh out the details of the logic, here are some questions.
how does the logic circuitry know if the furnace were not to be fired?
Are wood furnaces adaptable to zoning?
So, one input to the logic block is a flame sensor for the wood stove, another is the temp. of at least one room.
The outputs are DC signals? Switch contact closures?
Does the logic block need to store a program?
You want battery back-up?
Homebuilt logic will be $10 to $20 in parts and require some electronics know-how to assemble and test.
Commercially built logic will be much more bucks and will take some Internet searching and you still may need custom, but very simple, interfacing circuits.
And there is possibly a compromising of personal safety if this circuitry malfunctions. Above all it must not defeat the built-in safety equip. and sensors of your existing HVAC equip.
Old 10-04-2009, 10:02 AM   #3
Thanks for the reply, let me clarify.
No logic circuit is needed to detect flame. I want to have the existing dual fuel system to be the back up and to only come on if the temp gets too low in the house(thus the fire in the stove must not be able to keep up or has gone out).
The zoning portion is the house currently has two zones, they are controlled by duct zone valves I want to still have them operate as now but also with the new heat also.
I know I can accomplish the first issue by adding an additional thermostat but I worry I will not be able to control the temp in both zones.
Kyle
Old 10-04-2009, 10:25 AM   #4
So if the wood furnace can't keep up, as detected by a sensor or 'stat either at the wood furnace or in the house, a relay drops out and switches in your dual fuel backup system.
This part is easy.
Is it that you need the zone control 'stats to also work with your wood furnace? If so, post a schematic of the control circuitry of your dual fuel system.
Distance of Conduit from Radiator / Heat Source jjohanson Electrical 4 05-12-2009 12:39 PM
HELP -Looking for a new/different heat source jaw522 HVAC 15 08-05-2008 09:09 PM
Adding Geothermal heat exchanger to window unit richinok HVAC 4 06-23-2008 07:59 PM
Radiant Heat Flooring As Only Heat Source? digthisbigcrux Building & Construction 2 03-10-2007 12:33 PM
