Adding Heat Registers To Basement - HVAC - DIY Chatroom Home Improvement Forum
Old 08-24-2009, 05:52 PM   #1
Adding heat registers to basement
The finished part of my basement is about 25 ft x 12 ft x 7.5 ft high. Ceiling and walls are drywall- don't know if there is any insulation. The floor is tile.
There are now 2 heat registers on the side of a soffit running the length of the room. The near one is about 2 feet into the room, the far one is about 3/4 the length down. There are no return air registers.
Will adding additional heat registers in soffit increase warmth in room? Are there guidelines for how many vents are needed for a given space?
Unfortunately, due to house layout (chimney/fireplace and exterior wall) and basement layout (builtin cabinets along wall), cannot add vents in spots which are coldest. Register vents in soffit seems to be only possibility.
brick1930 is offline   Reply With Quote
Adding an upstairs attic space....how to heat it? lilerm8302 HVAC 2 04-10-2009 09:39 AM
How can I heat and cool basement? Leoskee HVAC 24 03-23-2009 03:07 PM
Basement ducting size??? firemanpato HVAC 1 01-15-2008 05:04 PM
radiant heat in basement plgrm HVAC 2 12-09-2007 06:41 AM
