Adding Heat Ducts To Existing Plenum - HVAC - DIY Chatroom Home Improvement Forum
Old 01-10-2009, 05:23 PM   #1
adding heat ducts to existing plenum
I am remodeling an existing finished basement and want to add two heat ducts in the drop ceiling and am not sure how to add the new ducts to the plenum. Is there a special cutting device to cut out a perfect circle to add the duct?
milcurt is offline   Reply With Quote
Old 01-13-2009, 01:27 PM   #2
Hole for new duct
A simple way is to trace the pipe on the plenum with a marker then
drill a couple of holes in it then
use tin snips to follow the line.
Make sure to wear good gloves to protect your hands.
tagra123 is offline   Reply With Quote
Old 01-13-2009, 02:42 PM   #3
If you don't have any other branches, but how far are you running the ducts?
Will you have to use a lot of elbows to get from the plenum to "point b"?
hvaclover is offline   Reply With Quote
Old 01-13-2009, 07:33 PM   #4
An old Tradesmen
Rewards Points: 7,278
Where are you adding the return, so the furnace can get the extra air you want for those supplies.
Old 01-13-2009, 07:52 PM   #5
I was gettin' to that Been . Aint as quick as i used to be.
Adding a room, tie in to existing framing rampeyboy Building & Construction 4 12-26-2008 03:16 PM
Adding Geothermal heat exchanger to window unit richinok HVAC 4 06-23-2008 06:59 PM
Adding can lights to an existing circuit TexasEd Electrical 1 06-17-2008 07:23 PM
Adding radiant heat to existing slab Seabass HVAC 9 04-27-2007 04:10 PM
Installing Central Air using existing heat ducts lvlacic HVAC 2 06-25-2005 12:47 AM
