Adding Heat To A Basement, Newbie Questions - HVAC - DIY Chatroom Home Improvement Forum
Old 01-26-2011, 05:19 PM   #1
Adding heat to a basement, newbie questions
I'm in the planning stage of finishing my basement and I'm trying to figure out the best way to heat the space. Here's the background:
I live in MN where it gets mighty cold. It's a 1920s house with an 1000 sqft foundation but only 600 sqft will be finished. There's currently no heating or cooling in the basement but the main floor is heated by hot water radiant heat and the 1/2 story second floor is heated by electric baseboards. The main and second floors are cooled by window AC.
For heating the basement, electric baseboard seem like the easiest install (I'm capable of the wiring) but the cost of electricity is pretty high.
The other option I've come up with is using hot water baseboard radiators running off our current boiler or some sort of dry radiant flooring using hot water from the current boiler. Here's where I get above my head, how do I know if my boiler has the capacity to be extended to heat the basement? Is that even possible?
I don't know if you can tell just from the numbers, but my boiler is a Burnham Series 2 (204H) with Input MBH: 96; DOE Heating Capacity MBH: 80; I=B=R Net Rating MBH: 94. I confess... those numbers don't mean anything to me yet.
Is there a way to know based on the info I provided? If not, what other info can I gather?
frizbplaya is offline   Reply With Quote
Old 01-26-2011, 08:49 PM   #2
An old Tradesmen
Rewards Points: 6,116
Your basement won't need much heat, so your boiler should be fine size wise for being able to handle that additional load. Unless it already can't heat the first floor.
Old 01-27-2011, 08:23 AM   #3
Rewards Points: 150
Pellet stove or wood
ianc435 is offline   Reply With Quote
Old 01-28-2011, 03:57 PM   #4
Thanks for the info. The boiler has been keeping up fine on the main level. Running the pluming and adding a second zone is above my head so I guess it's time to call in a pro.
Help with Heat Pump System Wiring AlanScott HVAC 11 10-10-2010 01:19 PM
Few questions about adding outlet in unfinished basement McSteve Electrical 14 02-21-2010 11:17 PM
newbie basement insulation/vapor ?'s bergerdude Building & Construction 2 01-03-2010 02:48 PM
Adding a heat source kafansler HVAC 3 10-04-2009 10:25 AM
Alternative Basement Heat C_J_GO HVAC 8 04-01-2009 02:51 PM
