Adding A Hard Start Kit - HVAC - DIY Chatroom Home Improvement Forum
Old 10-13-2012, 08:04 PM   #1
Adding a Hard Start Kit
Hi everyone!!!
I need to install a Hard Start Kit to my AC unit because the compressor is having a hard time to start with the voltage we get from the power company. I have read that I need to find out what type of compressor I have and/or my AC specifications. How do I do that? This is a residential unit located in Florida. Can you also suggest a Hard Start Kit brand based on your experience?
Thanks in advanced. RG
rgarcia1801 is offline   Reply With Quote
Old 10-13-2012, 10:21 PM   #2
JJboy's Avatar
You just need to know the tonnage of your unit to order the proper hard start kit. Avoid any hard start kit that doesn't have 5-2-1 relay
http://www.five-two-one.com/.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 10-13-2012, 11:50 PM   #3
Rewards Points: 72
Looks like they have overlapping kits, whats the difference between the U2 and U3? From a 4 ton perspective?
digitalplumber is online now   Reply With Quote
Old 10-14-2012, 12:01 AM   #4
JJboy's Avatar
U3 is better for 4 and 5 ton. It has a bigger start capacitor (MFD).
The Following User Says Thank You to JJboy For This Useful Post:
digitalplumber (10-14-2012)
Old 10-15-2012, 04:50 PM   #5
My inside unit says
PH/HZ 1/60. Motor HP./F.L.A 1/3 3.2
rheem model rbhc-21j11sfg
I see that is a one phase and 60 Hz and 1/3 HP. Which one should I choose then?
Thanks,RG
Old 10-15-2012, 05:49 PM   #6
JJboy's Avatar
Originally Posted by rgarcia1801 View Post
My inside unit says
Thanks,RG
Get the Condenser model number.
Old 10-16-2012, 05:47 AM   #7
AKA HVACTECHFW
Rewards Points: 1,208
you have a 4 ton unit. Get the CSR U3
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 10-16-2012, 05:49 PM   #8
Here is the condenser model number:
Old 10-16-2012, 07:47 PM   #9
Rewards Points: 72
Three and one half ton unit
digitalplumber is just a name for use here, I am not a plumber!
Old 10-16-2012, 07:59 PM   #10
AKA HVACTECHFW
Sorry, your indoor coil is a 4 ton coil. Your outdoor unit is 3.5 tons.
IT IS WHAT IT IS
Old 10-16-2012, 08:09 PM   #11
JJboy's Avatar
You need U2 for 3 1/2 ton condenser.
Old 10-21-2012, 05:31 PM   #12
Should I buy the run capacitor as well?
Thanks RG
adding plugs to hard wired light fixtures (exterior) marmkid Electrical 8 07-07-2012 09:36 AM
supporting air handler in auxiliary pan in attic slash5bmw HVAC 201 07-06-2012 10:42 AM
Hard drive redline PC Repairs & Upgrades 14 03-06-2009 04:27 PM
Changing poly type during hardwood floor refinishing redpen Flooring 17 02-03-2009 06:11 PM
hard metal vs. flexible ducts katea HVAC 4 05-18-2008 08:23 AM
