Adding A Fourth, Lower Speed To Fan - HVAC - DIY Chatroom Home Improvement Forum
Old 05-27-2012, 01:19 PM   #1
Rewards Points: 12
Adding a Fourth, Lower Speed to Fan
My window-mounted, evaporative cooler has a three speed, permanent
split capacitor (PSC) motor. A guy at a Home Depot review site for this cooler said he "added a fourth speed--1/3 of the lowest speed." He did not explain, and there is no email address to write him. Can anyone say how to do this?
Alternatively, what do people think of the following solution, using a dimmer?
Set the switch to "High." Disconnect wires from the low and medium speed terminals.
Cut the lead supplying power to the motor.
Add variable control in series. Use one of the dimmers that is variable from electrical supply stores. The dimmer must be a "triac" and not an "SCR." SCR's work great with resistive loads but not with inductive unless certain conditions are met.
Speed may now be varied down to about 20% of the motor's rated speed.
ElleNavorski is offline   Reply With Quote
Broan variable speed motor m0t0rgeo Electrical 1 09-22-2011 01:58 PM
Electrical Problem w/ New AC Blower Motors - High Speed shuts off after 15 Min? Tyndale Electrical 6 07-10-2011 03:58 AM
Is there a way to have heat, cool and fan all on same blower speed? pirateo HVAC 4 08-14-2009 04:13 PM
Trane XV80 - low speed fan not working oregondean HVAC 4 01-12-2009 12:46 PM
Heat Pump blower speed? ktkelly HVAC 1 07-18-2007 10:01 PM
