Adding Electric Boiler To Geothermal System - HVAC - DIY Chatroom Home Improvement Forum
Old 01-30-2011, 05:55 PM   #1
adding electric boiler to geothermal system
We have geothermal in our 2300sqft home. We also have lines going to the garage to heat the floor. The issue is that there isn't sufficient heat left over to heat the garage. I would like to install an electric boiler in line to raise the water temp. to 110 degrees. I have a closed loop system. i will be using a 10 kilowatt boiler.
falconger is offline   Reply With Quote
Old 01-30-2011, 06:14 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 336
Ayuh,... Sure, it sounds like a Plan...
Without knowin' how it's plumbed now, it's hard to say where/ how to do it....
Gas Boiler furnace or a new system? paulssn HVAC 1 08-29-2009 11:02 PM
Adding more weight to truss system... what can it hold? Sonnie Building & Construction 7 02-06-2009 09:45 PM
Electric current system v salt water softener? oasis Plumbing 1 01-30-2009 07:16 PM
Water level in boiler system Barefoot Brian HVAC 3 10-19-2006 02:11 PM
