-   -   Adding ductwork to basement from attic. (http://www.diychatroom.com/f17/adding-ductwork-basement-attic-109889/)
Squeakyhinge 07-06-2011 08:25 PM
Checked forums for ATTIC ac "reducting" and found only BASEMENT UNITS. I was wandering if taking ducts from attic to basement would create a different situation.
This is proposed floor plan of basement.
http://i1218.photobucket.com/albums/...asement3-3.jpg
The AC-ONLY air handler is in the attic with vents on ceilings of the main floor with basement under main floor of course. The house is heated with a boiler fyi.
I want to run ducts through a closet to proposed "family room" of diagram...fyi plans were reversed and now this will be a bedroom. I plan only one room for now, don't know if I will ever get to the other rooms, BUT wandering what the AC requirements will be for future other spaces especially the bath.
A couple questions: Use insulated flex duct or steel duct(with insulation added?)?
Is a return necessary and where to place vents?
Bring down "trunk" for future whole basement OR "branch" of one of existing "lines"?
I started to hang drywall on ceiling in basement and stopped because I must decide on the AC duct routing prior to drywall...this is why I'm being abrupt... thanks in advance for your help or direction...
Squeakyhinge 07-07-2011 07:57 PM
bump please, btw I'm not a pro, is the HVAC forum for "pros only"?
JJboy 07-07-2011 08:09 PM
Check Manual D and J
Squeakyhinge 07-07-2011 08:33 PM
You threw the book at me. I thought "insulated flex duct" vs "steel" is about condensation issues also, not just velocity and friction and all that. I'm going to have to find out my tonnage and do some other homework. As you wish, JJ. Thanks for reply.
beenthere 07-07-2011 08:55 PM
Basements take very little to cool them. But humidity will be a concern.
Squeakyhinge 07-08-2011 06:06 AM
Yes, I will have to rely on the dehumidifier. Wandering if I have two, will they run less or just suck more moisture? The one runs all the time at 50%. Thanks Beenthere.
beenthere 07-08-2011 03:51 PM
With 2, they won't run all the time. Once the humidity is below set point, they will shut off.
