Adding A Digital Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 08-30-2010, 06:27 PM   #1
Adding a Digital Thermostat
Hi,
I have a electric wall heater model R1500T2A installed in a bathroom in my ManCave. It currently has a knob type thermostat that is not very accurate. I use this room to brew beer and want to add a digital thermostat to it so I can maintain a good brewing temperature. Since the current thermostat has the 120v wires running into it I need to know where I can find a digital thermostat that will work with this model. Any advice will be greatly appreciated.
lostdog is offline   Reply With Quote
Old 09-01-2010, 01:35 AM   #2
Just use what wiring you already have and add a transformer from 120v to 24 volt t-stat. Very inexpensive, check KVA on 24 volt t-stat for rating, and if you have to just buy a wall plate exstension to put the small tranformer in.
lamon2524 is offline   Reply With Quote
Old 09-01-2010, 04:30 AM   #3
An old Tradesmen
Rewards Points: 6,570
They line voltage digital thermostats, that are alot more accurate then that old by metal thermostat that you currently have.
Old 09-01-2010, 05:04 AM   #4
Where you been? When have you seen the old Bi-metal lately. Low voltage uses OHMS that directly relates to temp.
Sorry BeenThere I thought you were cutting me. I'm a 30 year retired HVAC Tech. from a very large school system in AL. He was just asking for a cheap accurate way to upgrade.
Old 09-01-2010, 05:11 AM   #5
An old Tradesmen
No. Lots of bi metal line voltage stats are still sold today.
No real benefit in adding a transformer and relay system to use a low voltage thermostat, over installing a digital line voltage thermostat. Cost comes out to about the same for parts/material.
Line voltage digital thermostat is easier to install, and takes less time.
Analog thermostat to digital thermostat conversion problem godcomplex HVAC 8 01-13-2010 03:50 PM
Two Wire 24V Thermostat to Digital Thermostat on Pellet Stove jrodtaclet Electrical 4 09-15-2009 06:37 PM
Thermostat from Manual to Digital trinamillersmit HVAC 5 07-02-2009 10:21 AM
Replace Condo's 2 wire mechanical thermostat with digital thermostat kat83 HVAC 4 06-02-2008 04:44 PM
Replace Condo's 2 wire mechanical thermostat with digital thermostat kat83 Electrical 2 05-22-2008 12:52 PM
