-   -   Adding a Digital Thermostat (http://www.diychatroom.com/f17/adding-digital-thermostat-80085/)
lostdog 08-30-2010 06:27 PM
Hi,
I have a electric wall heater model R1500T2A installed in a bathroom in my ManCave. It currently has a knob type thermostat that is not very accurate. I use this room to brew beer and want to add a digital thermostat to it so I can maintain a good brewing temperature. Since the current thermostat has the 120v wires running into it I need to know where I can find a digital thermostat that will work with this model. Any advice will be greatly appreciated.
lamon2524 09-01-2010 01:35 AM
Just use what wiring you already have and add a transformer from 120v to 24 volt t-stat. Very inexpensive, check KVA on 24 volt t-stat for rating, and if you have to just buy a wall plate exstension to put the small tranformer in.
beenthere 09-01-2010 04:30 AM
They line voltage digital thermostats, that are alot more accurate then that old by metal thermostat that you currently have.
lamon2524 09-01-2010 05:04 AM
Where you been? When have you seen the old Bi-metal lately. Low voltage uses OHMS that directly relates to temp.
Sorry BeenThere I thought you were cutting me. I'm a 30 year retired HVAC Tech. from a very large school system in AL. He was just asking for a cheap accurate way to upgrade.
beenthere 09-01-2010 05:11 AM
No. Lots of bi metal line voltage stats are still sold today.
No real benefit in adding a transformer and relay system to use a low voltage thermostat, over installing a digital line voltage thermostat. Cost comes out to about the same for parts/material.
Line voltage digital thermostat is easier to install, and takes less time.
