Old 08-17-2013, 03:25 PM   #1
Share |
Adding a condensation switch
Hello,
I have owned an upstairs condo in central Florida since 2005. Over there years I have had a few times in which the condensation line has leaked and caused damage to the lower unit. Stopped up lines, found the PVC had not been glued at 2 joints also. The line was vacuumed just over 2 months ago and clogged again last week. I have used bleach to try and keep it clear and this time used vinegar. The A/C unit is in the center of the condo with vaulted ceilings and the drain line runs thru the floor. The drain line comes out of the bottom of the pan with a 90 degree elbow, does about 8" then another elbow and goes down into floor. I have been told I can not add a float switch. Is this true? can't I put one into the 8" pipe? If that's too low can't I T up and add it at the pan level? I have thought of adding a pump but not sure how to run the new line. If I can install a switch what kind, where in the line, and how? Any ideas would be appreciated.
Thanks,
Ken
Adding a condensation switch-img_20130812_200056.jpg   Adding a condensation switch-img_20130812_200112.jpg
ffltstn is offline   Reply With Quote
Old 08-17-2013, 03:39 PM   #2
Looks like you need to clean the coil.
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 08-17-2013, 04:08 PM   #3
An old Tradesmen
Install an E Z trap with switch.
http://www.younits.com/ezt210-standa...ap-p-5324.html
Also, that coil needs cleaned, and is probably why your drain line is clogging up so fast.
The Following User Says Thank You to beenthere For This Useful Post:
hvactech126 (08-18-2013)
Old 08-18-2013, 03:45 PM   #4
Yes I saw that it needed cleaning, but I did not realize that would stop it up faster. Thanks for letting me know
I had also saw the Safe-t-switch which is similar and found the Diversitech SOS-1 which looks the easiest to install.
Anyone have any experience with it?
ken
Old 08-18-2013, 07:24 PM   #5
AKA HVACTECHFW
The SOS-1 is nice, but I really don't trust it compared to a float switch on a trap like the one that BT suggested.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Adding a wall switch to a closet light that was a pull switch BlueBSH Electrical 2 02-04-2013 05:58 AM
adding wall switch to pull chain light, gone wrong. dim chandelier Electrical 4 01-28-2013 08:07 PM
3 way switch adding an add'l light GRed Electrical 2 12-15-2011 04:24 PM
adding second light from a switch agsurfer Electrical 3 09-10-2010 12:01 PM
adding 3-way switch to existing circuit msahaydak Electrical 4 02-18-2007 12:43 AM
Copyright © 2003-2014 Escalate Media. All Rights Reserved.
