Old 04-28-2009, 09:31 AM   #1
Question
adding central air
My wife and I are house shopping, and what house that we both like lacks one of the big desires for a new home - central air.
To make matters worse, it's oil / hot water radiator heating.
Someone that I know who knows (or seems to) more about home improvement than I do mentioned he's seen a central air retrofit system that uses flexible hosing and small nozzles instead of duct work to cool the rooms. He said it's a lot less expensive to install because it's a couple 4" holes per room instead of cutting out big sections of plaster and lathe to get ducts in.
Does this exist? Does it cool well?
The house we're looking at is a 3 story 1900's era english tudor - plaster lathe walls, beautiful wood work etc. First floor is kitchen, dining room, foyer and living room - 2nd floor is landing and 4 bedrooms.
Can someone estimate a very very rough ballpark price to add central air to the first 2 floors? Are we in the $10-$15K range or $25K and up? We really have no idea of what range we'd even be looking at.
And also - what is the price range to convert the burner from oil to natural gas? The hot water heater is gas, so there's a feed coming in.
Thanks - I know they're general questions, but even rough rough rough rough ballpark estimates should give us an idea.
poger67 is offline   Reply With Quote
Old 04-28-2009, 10:25 AM   #2
I have gas!
Clutchcargo's Avatar
adding central air
I think what you're referring to is high velocity air-conditioning. I don't know if it's cheaper to install but the air-handler and flexible ductwork is very expensive.
On a different note, my neighbor just installed standard ac to his ~1500^2 ft house. He paid $10k in the Boston, MA area; that included new duct work.
I tear things down and build them up.
Clutchcargo is online now   Reply With Quote
Old 04-28-2009, 10:45 AM   #3
An old Tradesmen
adding central air
Your refering to a High Velocity system.
They are not cheaper to install. They are more expensive to install.
No way to know price without seeing how hard it is to install the system.
Although conversion burners are made. They are inefficienct.
Better offgetting a new gas boiler then just converting the old one.
Old 04-28-2009, 10:58 AM   #4
It was a dark and stormy
Yoyizit's Avatar
adding central air
Any other options besides central air?
What's your Cooling Degree Days and max temp/humidity?
http://www.degreedays.net/
Tags
add central air, convert burner, oil heat
Adding Central AC? KGP HVAC 47 05-28-2009 01:08 PM
Adding more weight to truss system... what can it hold? Sonnie Building & Construction 7 02-06-2009 09:45 PM
Adding new duct/Register CEbury HVAC 1 06-25-2008 11:51 AM
Adding Central Air rondo HVAC 1 05-27-2007 10:03 AM
Installing Central Air using existing heat ducts lvlacic HVAC 2 06-25-2005 01:47 AM
