Adding Air Elimitator To Boiler System. - HVAC - DIY Chatroom Home Improvement Forum
Old 08-19-2009, 12:28 PM   #1
Rewards Points: 406
Adding air elimitator to boiler system.
I'm replacing the baseboard heating units in the basement with new slantfin ones and I figured while I'm at it I should add something to bleed the air out when i got to re-fill them. I can flush the system now but I'm worried air will still be trapped in there so what's the best connector and placement to install to help prevent air in the system?
Sorry for the bad image, it's to show that the boiler and baseboard are on the same level. The pipe goes up from the boiler in the ceiling and then back down tot he baseboard. The baseboard then runs a long the wall and loops back to go back to the boiler the same way.
RyanD is offline   Reply With Quote
Old 08-19-2009, 02:19 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
You can automatic or manual bleeds at the highest point of the piping.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Boiler size Bonnie Youngs HVAC 29 07-10-2009 07:58 PM
Swapping the old boiler system to tankless tomesmalls HVAC 2 02-11-2009 03:38 PM
Adding more weight to truss system... what can it hold? Sonnie Building & Construction 7 02-06-2009 08:45 PM
boiler / Over-pressurizing cparke HVAC 1 05-21-2008 05:54 AM
Weil Mclain Boiler air in system manning01 HVAC 11 10-06-2007 10:35 PM
