Old 07-29-2010, 09:45 AM   #1
Adding a 5" service duct to basement rooms
I have new rooms I am framing in my basement. Can I add registers (one each) to the existing 5" service ducts that service the first floor? These ducts are in between the overhead joist are easy to access.
In other words, can one 5" duct service two registers, or must I add a new 5 "duct to the main trunk to service a basement room?
S Wojo
sakskc is offline   Reply With Quote
Old 07-29-2010, 06:26 PM   #2
You won't get much air flow to any of those register trying to split it up like that. Take it back to the main trunk. I never use pipe smaller then 6" unless it's going to a tiny bathroom.
Adding 100amp Subpanel for basement trajendra_babu Electrical 22 06-12-2010 10:54 PM
Adding basement supply's to trunk line emarlin HVAC 12 04-20-2010 12:42 PM
Adding heat supplies and cold air returns to basement RAYCC3 HVAC 0 09-14-2009 02:57 AM
Adding power to my basement tandyt Electrical 1 05-04-2008 06:52 PM
Basement receptacle under service panel mekanic Electrical 2 05-12-2006 06:41 AM
