Added O.s.wood Boiler,how To Hookup 2nd Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 11-16-2009, 02:13 PM   #1
added o.s.wood boiler,how to hookup 2nd thermostat
i have added o.s. wood boiler,now thermostat, and aquastat need to be hooked up,this is a second thermostat that woks till the aquastst says it is not hot enoughand then my old thermostat kicks in and fires my furnace from gas.the thermostsat i am hooking up only should kick the fan in, i have an water to air heat exchanger in plenum. what setting should i set the aquastat at?? i did run 5 wire thermostat wire. what color wires go where?? also second furnace will also have a zone valve because it is a downflow.
geobckmstr is offline   Reply With Quote
Two Wire 24V Thermostat to Digital Thermostat on Pellet Stove jrodtaclet Electrical 4 09-15-2009 05:37 PM
Replacing thermostat...................... sktn77a HVAC 6 09-02-2009 10:07 PM
Thermostat wiring jetmanaz HVAC 1 08-09-2009 07:13 PM
Thermostat from Manual to Digital trinamillersmit HVAC 5 07-02-2009 09:21 AM
