Add On Wood Furnace Back Flow - HVAC - DIY Chatroom Home Improvement Forum
Old 06-17-2009, 08:46 PM   #1
got it
mathews is offline   Reply With Quote
Old 06-17-2009, 09:03 PM   #2
An old Tradesmen
Rewards Points: 6,124
You buy it.
They are low leak dampers.
Old 06-17-2009, 09:40 PM   #3
Will it handle the heat? It will only be 6 inches from the top of the gas furnace.
Old 06-17-2009, 09:47 PM   #4
An old Tradesmen
You need to order a high temp one.
Old 06-18-2009, 06:04 PM   #5
Any idea where to order a high temp one from? What is the correct name for it?
Old 06-18-2009, 06:20 PM   #6
An old Tradesmen
Graingers.
High temperature Backdraft damper.
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Ext Paint for Interior Application? PaoloM Painting 24 04-21-2009 05:30 AM
flooring frankiedog Flooring 7 12-05-2008 02:05 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
Filtering an up flow furnace without filter grills Rookietinner HVAC 1 11-20-2008 12:20 AM
