Add Gas Line - HVAC - DIY Chatroom Home Improvement Forum
Old 01-01-2006, 09:24 AM   #1
Add gas line
I have a gas furnace and want to add a gas dryer and a gas oven/range. Is a copper coil line of sufficient size to feed gas to the dryer and also the oven/range?
thanks
Christo is offline   Reply With Quote
Old 01-01-2006, 11:33 AM   #2
That would not be allowed in my area but i've seen it used in NC. HS.
K2eoj is offline   Reply With Quote
Old 01-10-2006, 07:41 PM   #3
weinstall.ca
Post
thanks
gas technichicians in ontario are allowed to use copper approved for gas.
But it depends how far you are running your line,
Also how many btus your unit is
Make sure your gas installer is licensed.
Allan
Clarkson Comfort Zone Heating and Air Mississauga
weinstall.ca
allan is offline   Reply With Quote
3/4" gas line needs to be bigger raymond_anthony HVAC 11 10-28-2009 05:59 PM
Condensate Line schott HVAC 17 06-02-2008 03:16 PM
how to run fridge water line under kitchen floor? travishume Plumbing 23 09-26-2006 07:51 AM
Relocating water supply line from well Mikedks Plumbing 6 09-22-2006 01:41 PM
Installing exterior faucet to washer line? skellies Plumbing 3 06-18-2006 08:19 PM
